Viore IPT46DL30 has no power, it was working fine and plugged off and then put back to turn on, but noting now , no light and didnt start at all.
    Genius:
  • 1,126 Answers
Check the output on the wall to make sure you have voltage. If you do then you have a open fuse in the set on the power supply, or the power supply is dead, in the set. You can get a new power supply at www.partstore.com
Posted on Oct 16, 2010
Jeep 2008 Liberty. I have a normal starting key, i go into my car 2 hours after it was working fine, the dashboard lit up fine and the radio too. But the engine would not even budge. I dont think its the...
Something worth trying. The voltage on the battery being fine may not guarantee that it's making it to the other end.
I might try taking the battery clamps off and cleaning them and then make sure that they're put back on very securely.
It requires very little power for lights and radios to work, it takes enormous power to turn over an engine.
I hope this helps you.
Jan 24, 2011 | 2008 Jeep Liberty
My viore 32"lcd hd modle lc32vx60hdt will power up
The tv Tuner signal board is dead,that the board where the incomming broadcasting signal cable plug in it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 13, 2011 | Televison & Video
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
VIORE TV IPT46DL30 shows no light but power ins going to set??? is there a reset putton???
This tv has no serviceable fuses inside. You may need to replace the power supply module.
Nov 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a viore monitor ipt46dl30 which just went black but we can still hear the voice.. help?
I'm in the process of ordering a replacement bulb for a friends set right now. The information below is exactly what's needed to get the correct bulb for this DLP television.
TV Make: Viore
TV Model: IPT46DL30 (Confirmed to be on TV label)
Bulb/Lamp Model: SHP70 (This number is right at the top of the bulb/lamp, where the wires connect)
Housing Model: 140-1027 (This is also known as the Ballast which houses the bulb/lamp)
Now, I've managed to locate the bulb/lamp from a few different sites. Unfortunately, there doesn't appear to be a reputable manufacturer making aftermarket bulbs for this DLP model. The original bulb type is all we have to look forward to. The cheapest price that I've found so far is $120.00. I have also found these particular bulbs for as high as $295.00. Needless to say, I'm going with the former.
http://www.replacementlightbulbs.com/lampshp70.html - $120.00 (Buying)
http://purelandsupply.com/140-1027-Bulb-Akai-DLP-TV-Lamps.html - $277.90 (Too much)
http://www.encompassparts.com/products/?140-1027 - $295.00 (Too much & very skeptical)
Mar 31, 2008 | Televison & Video
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
