Question about Mitsubishi WD-65731 65" HDTV
Have a mitsibishi wd-65731 dlp tv. Problem- my daughter want s tp play her Wii game on it and when she plugs it in all she gets is black and white. tryed the Wii on another tv and it comes on in color so it is not the game console. tryed the front and rear inputs- no change. tryed the vidio button on the remote to set color and brightness settings and moving the slides makes no change. Help!!
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
  • 1030 Answers
SOURCE: wd-65731
AIr flow is blocked?.....is this the message you get on screen mitubishi have a problem with what is called the thermal sensor.. the processor says its getting to hot... mitsubishi suggest service center replace this thermal sensor.
Posted on Jun 02, 2008
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
SOURCE: mitsubishi DLP WD 65731 TV
power supply is sending less than 135v to the ballast
Posted on Feb 04, 2009
  • 1039 Answers
SOURCE: Changing the lamp on a Mitsubishi DLP WD-65731,
Look inside the tunnel with alight see if the contact plug is straight. Sometimes this plug can get bent to the side a little.
Posted on Sep 02, 2009
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
I dont know if it is my wii but my tv is black and white/grey and white what can i do to repair it?
If your TV is only black and white while playing on the Wii, this is indicative of a problem with either the A/V cable or the A/V ports on your television.
If you have a friend who owns a Wii, try using their cable, or change the A/V jacks to a different set of ports on your television.
NOTE: The A/V jacks are the red, white, and yellow plugs that plugs into your Wii on one end and into your TV on the other. If, for example, these jacks are under VIDEO1 on your TV and you switch the viewing mode to VIDEO1 to play Wii, then try moving them to a set of A/V plugs under VIDEO2. If this is an older TV, there may be only one set of plugs on the TV itself. Try the console on a different TV. It may be time to get a new television. This often happens on older TV's.
May 04, 2011 | Nintendo Wii Console
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
Changing the lamp on a Mitsubishi DLP WD-65731, when trying to put back the cartridge, it semms that it does not go all the way in since the two screws do dot reach the nut.
Sep 01, 2009 | Mitsubishi WD-65731 65" HDTV
Wii plays in black and white.
Check if the tv has different types of AV settings, as this affects whether the wii plays in black and white or colour.
Aug 04, 2009 | Nintendo Wii Console
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Wii video is black and white
Possibly you've plugged the video into the component (RGB) portion of the input - this calls for 3 connectors (Red, Blue, & Green) and if you only plug one in from a composite it comes out grayscale. If you only have one video lead (yellow connector) make sure it is going to a composite connection which should also be yellow. Otherwise, more info is needed about your connections.
Nov 02, 2008 | Nintendo Wii Console
Mitsubishi WD-65731 65" HDTV Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
