Question about Ovens
No heat at all - Ovens
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 16, 2010
Pre-heat oven, insert food, after few minutes, stove shuts off - no heat.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 10, 2011 | Kenmore Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
I have a Fridgidair ES 300 Electric Range and my oven will not heat in the Bake cycle. The display comes on like it is heating up but no heat. Broil cycle works.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 11, 2010 | Frigidaire Ovens
Pre-Heated my oven, it beeped and I put muffins in. They began to cook and suddenly oven lost heat. When I try to pre-heat now, it clicks as if it is pre-heating but I am getting no heat. I have checked...
heatman101
Aug 10, 2010 | Kenmore Ovens
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Unit will not heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
gkjkgj
Sep 28, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven on RF263LXTT2 does not maintain a constant heat. Oven heats, but doesn't seem to continue heating at a constant heat during the baking process. Both coils heat up during the preheat. Seems like once...
The problem looks like a faulty electronic control. When you select baking, the broiling element should not come up.
Before replacing control assembly, test the temp probe located inside the cavity, check the wiring harness to temp probe and elements, and ensure that the fan is working if the oven is fan assisted.
Sep 18, 2009 | Whirlpool Ovens
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
