Question about Belkin Wireless Surf Router (F7D2301)
After I've connected the router to the modem, the light still in red. What should I do?
  • 1,188 Answers
You MUST reset the modem when you change connections. Unplug the modem from the power for 30 seconds, then plug everything in and giive it a go. It's usually that simple.
Posted on Oct 16, 2010
How do i get my wi fi to work again? i've owned it for 14 months w/no problem. Now it wont connect although i'Ve got the same security (WPA/WPA2 PSK and password,It just working this...
First trouble shoot would be:
Connect your PC directly to the modem and see if you have internet access. If so, then just reboot the router.
If not, unplug the power from the modem and the router.
Plug the power back into the modem and wait 2-3 minutes (to make sure it talks to your service provider. Again - you can connect your PC to the modem and test.)
Then plug in the router and see if that connects (is there a light that indicates connectivity?)
If you did not change anything in your router setup, it should come back up.
If these steps don't solve the issue, please come back here and let me know.
Fingers crossed!
Jan 19, 2015 | Nextbook Tablets & eReaders
Red light on modem's internet
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
Connecting to my network
Its not a modem its a router. A Modem plugs in to a Telephone line. A Router plugs in to a Broad Band Line. A Modem connects to a RJ11 Cable. A Router Connects to a Coaxial Cabal, the router connects to a computer via wireless or ethernet after that. A Modem connects to a computer using RJ11 or RJ45 Cat4 Ethernet. Very different.
Aug 26, 2012 | Dell Computers & Internet
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
I just bought a Belkin wireless router for my internet to connect with my microsoft xbox 360 wireless adapter. the light turns on the adapter but it is a amber color and not red or green like always...
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
Dec 31, 2010 | Microsoft Xbox 360 Console
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 04, 2009 | NetGear DG834G Router
Wont connect. power light is red. wireless light is green. i have a 2701hg-b 2 wire. i ve tried diconnecting, resetting, but the gateway remains the same. what do i do?
I've got the same issue, 2 wire claims that whrn the power light is red, the modem is bad and must be replaced. I would try and power the modem from another circuit before replacing. I am replacing mine today
Jun 24, 2009 | AT&T High Speed DSL Modem
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
Belkin Wireless Surf Router (F7D2301) Logo
336 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
