Question about Haier 65-Pint Dehumidifier
Humidifier not taking out water
We bought a brand new Haier dehumidifier yesterday, took it to the basement, turned it on and tonight the bucket is empty! Not a single drop of water to be seen. There should be some moisture present.
  • 6 more comments
  • Anonymous Jun 04, 2008
    Same here. Humidifier runs for hours, but no water. Room temperature is about 66. It did work well for the first week.
  • Anonymous Jul 02, 2008
    runs but no water in tank
  • just4way Jul 14, 2008
    I've had my for about a week .... not one drop of water.
  • zouks Aug 28, 2008
    I bought this less than a week ago runs at 73 degrees with 73% humidity according to display. However I have not seen any water inside bucket. The lowest it has run down to is 63%, and it cant maintain. Basement is 400 sq ft. I have to run industrial fans to keep basement dry
  • Anonymous Sep 09, 2008
    First unit did nothing. Second unit lasted a month. This unit is a lemon.
  • Anonymous Nov 05, 2008
    I have the same problem with the humidifier not taking out any moisture any more - when we first got it and used it for a month it was working great and I was emptying the bucket in the morning and at night - now it is not doing anything. What is the problem?
  • pshah765 Apr 30, 2009
    dehumidifier not picking the water, unit not too old.
  • Anonymous Mar 28, 2014
    It sounds like its running but it takes in no water.
On my third unit.
First unit worked well (but loud) died in 5 weeks, replacement (14.99 to ship) was DOA, third unit appears to be working. Horrible bucket design, it's impossible to remove and carry when full without spilling. Float level is set too high, no adjustment..
Would not recommend.
Posted on Jul 08, 2008
  • 3 Answers
I just bought one also, and noticed the following:Both units I tried iced up at any temp below 70 degrees! The box states that it will run with temps down to 41 degrees, and the manual states that it might ice up at any temp below 60 degrees. Try putting the unit on a table or as close to the ceiling as you can where the temp is higher. (Heat rises) This allowed my unit to run normally.Another thing I noticed about this unit is that it turns off when the set humdity is reached, then as the humidity rises the unit cycles on and off numerous times until it finally stays on. Luckily, it is only the fan cycling, and not the compressor.Also, the second unit I tried vibrates (buzzes) quite loudly, whereas the first unit did not make any noise.So far, I am not very impressed with this unit, and I will probably take it back to BJ's where I bought it. Hope this helps
Posted on Jun 28, 2008
I have the same problem. I have had the unit less than a month. Haier's policy is for me to pay $14.99 so they can send me another one. What a huge ripoff.
Posted on Jun 26, 2008
Dehumdifier runs but there is never no water in the bucket and our basement is very damp from all the humidy and the floor is sweeting there should be water in the bucket
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 07, 2011 | Haier HD308 Dehumidifier
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
heatman101
Jul 18, 2011 | Haier Dehumidifiers
I bought a Dandby dehumidifier brand new yesterday and it has been running 24 hours in the basement. It has not collected a single drop of water. The display says the humidity level in the room is at 30%...
heatman101
Jan 23, 2011 | Danby DDR4010E Dehumidifier
My basement has condensation in the walls, but the dehumidifier won't turn on. It is plugged in and the bucket is empty. Not sure what the numbers have to do with the machine turning on, but I have...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 26, 2010 | Haier HD656E Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Humidifier just not working!
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | Goldstar DH304 Dehumidifier
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Haier Dehumidifier not removing moisture
After total frustration, we took it back to the store and got a refund. They told us so many of these have come back, they were surprised they haven't been recalled yet. Thanks anyway.
Jul 21, 2008 | Haier HDN655E Dehumidifier
Haier 65-Pint Dehumidifier Logo
1,199 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
