Question about GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint side by side.No ice is produced.Switch is on.has new water filter,freezer cold.
    President:
  • 1,891 Answers
Is freezer colder than 15 deg / is light blinking on ice mker or is it solid . filter does not cause no isc problem . mm
Posted on Oct 16, 2010
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Just hooked up the water line to my hotpoint side by side. There is no water running to the ice maker. The switch is on in the freezer. Is there something else to check?
Did you install the water filter. If you have, possibly it needs replacement. (blocked). Water has to run through filter first.
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator Leak and Freezer NOT COLD
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 03, 2009 | Hotpoint HSS25GFP Side by Side...
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
