Question about Speed Queen AWS44NW Top Load Washer
WHY MY MACHINE HAS STOP WRING MY CLOTHING DRY, AND WATER REMAINS IN WASHING?
  • 618 Answers
Check and see if the lid switch is working . Should hear a click sound as you open and close the lid.
Posted on Oct 16, 2010
My Whirlpool super capacity 2 speed 7 cycle washing machine filter is dirty because it makes marks on clothing. Any suggestions on how to fix this please. Thanks Regards George
Hi, sometimes even after cleaning the filter dirt remains in the machine. The best thing that can help solve this problem is to buy a descaling powder for washing machine (available at supermarkets or hardware store) and follow the instructions on the box or packet, this will take awhile as you will have to stop the cycle by turning the power off when the machine is full of water (with no clothing in it) and then restart the cycle, (about 2 hours). Descaling is necessary as the soap powder attaches itself on the rear of the rotating drum and cannot be seen and some dirt(streaks) will appear on the washed clothing. Hope this helps. All the best.
Apr 28, 2015 | Whirlpool Washing Machines
Items not dry enough after spin cycle, some water remains in machine
This is normal. It depends on a number of factors, including the type and volume of clothing you are trying to wash. Usually, it is not a machine issue.
Dec 06, 2013 | GE Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Washer is plugged in and it won't start or open?
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring the contents up-either an agitator in the middle of a top- load machine or a rolling drum in a front-loading machine.
Gazebo, Patio Heaters,Heated Towel Rails
May 09, 2012 | Washing Machines
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
WHY DOES MY SPEED QUEEN MACHINE HAS STOPPED WRING MY CLOTHING DRY, AND WATER REMAINS IN WASHER
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 16, 2010 | Washing Machines
My washing machine makes machine gun sound and doesn't wring out clothing properly...noise is only on wringing out cycle
Interesting... I don't have a solution, just a related problem. Belt broke and after repair, I observed that water is leaking from the bottom of the tub during wash cycle. I guess it could be a cracked tub (not too likely) or a gasket around the agitator bearing. I'd like some advice on this as well.... and how to get to it. The drive belt was a pain....
Sep 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Spin cycle does not take all the water out
Check the coupling between the motor and gear housings. It should be a rubber piece sandwiched by plastic piece. It could be broke. Just happened to mine. That prevents the maichine from spinning the cloths dry.
Mar 01, 2009 | Whirlpool LTE6234D Top Load Stacked...
Water not wringing out
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Speed Queen AWS44NW Top Load Washer Logo
180 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
