Question about Toshiba 50H81 50" Rear Projection Television
1992 toshiba big screen rear projection tv model tp-55902
Screen has shadowing on inside just got it and viewing appears to be harder at some angles seems like moisture or dampness where it was stored on inside of screen see like a mold pattern on outside of screen and doesnt wipe off so must be inside how do i fix it and wat do i use to clean my screen inside and out if u can help me would be great thanks
Let a stinkt fart on the upper right corner of the TV and that should fix the problem.
Posted on Jun 03, 2008
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
Oct 12, 2009 | Toshiba 51H84 51" Rear Projection...
Blue and red shadows on the TV picture
open up the TV then clean up the silver screen and the 3 light bulbs inside its probably just dirty.
Oct 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
I am seeing green and red shadows and in the corner the shadow goes up at an angle Help
Ur convergence is dead.U know how to solder?Tries this website.Tv Repair World.com.Buy ur tv model convergence kit,and repace it.
Sep 07, 2009 | Toshiba 50H82 50" Rear Projection...
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Shadow on Flat Screen TV
Projection TV correct? This may take some work but it is common for a spec of dust to settle onto the Mirror inside the TV, The back side of the TV screen or onto the Lens from which the Video image is projected. Some TVs have ports that allow you to access the inside of the TV from the side, others you must remove the screen.
This is not something to do every day or every week and it will not improve the picture. You only do this when you notice that it is dirty. Any more than that and you yourself will create a bigger problem. ONLY LIGHTLY DUST the screen. Soaps, water and windex will leave streaks, damage the screen and cause more trouble.
Projection TVs are the eqivalent of a big flashlight showing onto a wall. Put you hand in front of the light and you get a shadow.
Inside you TV there is a light (the TV picture) that bonces of a mirror attached to the inside of the back of the TV. The light reflects off the mirror onto the back of the screen. You view this refelected image from the front. Spiders commonly make webs inside the TV that appear in the picture. Dust Bunnies may get blown into an area and become stuck in the way. Sometimes a lite tap, shake or blow may remove this also.
Dec 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TOSHIBA 42PW23P rear projection television
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2008 | Toshiba TP43H95 43" Rear Projection...
Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
