Question about LG RH-4820 DVD Recorder
Hi My RH4820W is playing up on me. It just went dead. I tested at the fuse for power, yes there was. The cooler fan is coming on now and then and the D101 light ( not sure what it is) is flashing continously and normally. Do you think there is any reason for this? PLEASE GIVE ME ANY ANSWER
    Genius:
  • 1,126 Answers
.It is possible that the unit was hit by a small power surge, and the processor has some garbage in it, and you need to leave it unplug from the wall for 40 MIN, and that will reset back to normal.
Posted on Oct 16, 2010
I have 96 isuzu trooper3.2l v6 stick shift all power is good but when i stick key in switch and turn it no sound at all what could that be
electrical power you meant is seems good.
engine power zero.
starter dead.
this is no crank, ill post again,. for this, done so many times.
i use this thing called a voltmeter and avoid this jiggery pokery below...... time is money.
1: fuses good.battery terms clean? (all fuses, if you lack the FSM to see which ones are IN PLAY.)
2: battery charged to 12.6vdc reseted?
3: jumper cable cranking work now>? off a running donor car?
yes, the battery was dead, or weak, or discharged, test battery, test cars charging system and last make sure no drain on battery parked keys out of car..
4: NO, jump fails.
check or bypass clutch switch?
this cranks ok, (bad clutch switch at its pedal.)
if still dead it can be bad key switch or bad starter relay.
lets see if it has the relay. ,alldata.com says yes.
so does the starter relay close, cranking?
if not fix cause that first.
it needs fuses working
it needs power to the relay contactor input
power to the coil
and the coil enabling factor the clutch depressed and its switch must be closed.
and if the antithieft box, (factory option) is unhappy
the start relay coil will be dead.
start at the relay ,
does the (turned on) dash heater fan cut off, cranked
yes, then relay is closing
no, its not. find reason.
easy with a volt meter the 4 pins on relay.
pins 3,4,5,6
12v, 12v, 0v and 12v respectively.
if the pin 5 never goes to 0v, the immoblizer is unhappy.
sorry so small, Fixya shinks it to useless....
May 12, 2015 | Isuzu Cars & Trucks
The unit is completely dead. no lights and no fan. Both fuses on the board are good.
If it is dead, and doing nothing at all, have you checked to make sure its not a power failure to the unit? Sounds to me that may be a problem if all is dead. You probably checked this first, but make sure. I repair wine coolers, walk-in boxes on a day to day basis, and if you have no lights or fan, and nothing at all is coming on, it is either a power failure coming in or the power cord its self has come loose to the control section. That's all it could be, you have lost power. Check for power at the board if you have power to the outlet. The reason I believe you have no power to the unit is you say the light and the fan are off, and nothing is working. Please check and let me know.
Sincerely,
Shastalaker7
A/C, & Refrigeration Contractor
Jun 07, 2011 | Cuisinart CWC-1200 Wine Cooler
Microwave has no power the powe sourse works
Hi, your microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
The whole thing went dead, even the digital tempurature display.
Since everything went out, I would first test the outlet. Get a lamp and plug it in to see if the outlet is still active. Take the appropriate action if there is no power (check circuit breakers)
(p.s. Circuit breaker ONLY TRIP when you exceed the current load for that breaker)
If the out let is good (the light turns on) then:
Based on the reading of the owners manual, I did not notice any incident or mention of a fuse or power protection. Due to the sensitivity of wines , I am nearly positive this is an omission in the manual.
If you can get to the back of the unit, look around the power cord area to see it there is a fuse port. If there is a rocker switch to turn it on, the fuse may be in the switch.
this is your manual:
http://www.beveragefactory.com/images/guides/dwc512bl.pdf
Hope that helps
good luck and don't forget to vote!!!
Sep 30, 2010 | Danby Silhouette DWC512BL Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
GE built in microwave is completely dead. We were using the timer when it went dead. The A/C outlet is good. There was a pop sound just before it went dead. The unit is about 6 years old. Is it worth...
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | GE Microwave Ovens
My wine cooler does not cool
others have writen in one of your fuses (sodered in) my the bottom one.
not sure why yet.
May 26, 2008 | Haier HVT12ABS Compact Wine Cooler
Panasonic NN-P294SF dead
Yes, there will be a fuse and also on or above the magnetron, there will be a thermal cutout or thermostat, and one on the top of the cavity.
But here is our long answer on a dead microwave:
If the fuse is good, it may be an open thermostat or thermal cutout / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 19, 2008 | Panasonic NN-P294SF Microwave Oven
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
LG RH-4820 DVD Recorder Logo
224 people viewed this question
Computer Repairing
Computer Repairing
