Question about Panasonic PT-51HX40 51" Rear Projection Television
Panasonic PT-51HX40B We have had this TV for about 4 years, it was manufactured in August of 2000. Today when I tried to turn it on, it is just a black screen and it makes this clicking sound. Any ideas on what it could be and how much it would be to fix it? Thank you.
  • Penguin1 Jun 15, 2008
    My TV had the exact same problem as you said on year ago. I have the Panasonic's authorized service center to repair my TV costing about US$600.00. But now my TV has no picture again only with sound normal. I don't know if I should repair it again. Maybe I will throw the TV as garbage and buy differnent brand of TV, no Panasonic anymore.
  • vinkfink Feb 20, 2009
    I have the exact same problem. Does anyone have a solution? Also before the screen went blank the tv had a convergence problem, which I believe is caused by a bad chip. Any help or advice is greatly appreciated. I wondering if this tv should be trashed?
    Problem Solver:
  • 9 Answers
Check the board first, this it burned?
Posted on Aug 23, 2008
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
I have a 53" rear projection Panasonic tv in my
my name is rico, i work on tvs sometimes, if your tv is not dtv wont work unless buy a converter box if you need more let me know my phone number is 602-810-7149 in mesa az.
Dec 29, 2010 | Panasonic PT-53WX42 53" Rear Projection...
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-51HX40B turns itself off and has no video, no lights
The buzzing noise that you were earing came from a bad ballast, and because of the bad ballast your lamp must have got out also, and that is were you are getting the burned smel from and also that is why you are no longer geteting any picture either.
So in this case you would have to replace the ballast board and the lamp on your tv set.
Jul 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
The television shuts off automatically
What he may be referring to is caps to stop the coolant from leaking on the curcuit board. One time I had to put a drip pan in my set to stop the overflow. Expect a $300-$450 bill.
Jun 23, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
No picture
You can get the full service manual emailed to you at the following link, and when you buy the manual that entitles you to free online tech support that will help you track down the trouble and do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 18, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX40B convergence issue
Hi.....
Bit of a long shot but have you tried this??
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Hope it helps!
Richard
Apr 28, 2008 | Televison & Video
Panasonic PT-51HX40 51" Rear Projection Television Logo
195 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
