Question about Frigidaire Refrigerators
My fridge is not cooling properly; this happened last year and someone came and changed the drier filter. is this something thaat I can do or do we need a service call?
  • Andrew Lauder May 11, 2010
    What model and make is it. I don't think it is going to be your drier though.
    Sgt 48
    Scholar:
  • 110 Answers
Fg has had an issue with improperly install driers from the factory but if you have had this done already you should not have that probelm again. fg and maytag have had compressor issues on models built between 2002 to 2006. these are call sealed sys repair and only a certified tech can perform these duties. refer to you users care guide for warranty if they still apply, according to your date of purchase
Posted on Jun 03, 2008
My refrigerator dryer becomes cool & freezer doesn't
That filter drier is restricted. replacing filter drier will make your fridge cold again.
Nov 18, 2015 | Refrigerators
My one year old (but new condition) LG fridge was left nicely wrapped up inside the box unused for over 6 months as I was travelling. After I returned home, I unpacked it, cleaned it up and put it on to...
first question, Did you contact lg and they sent a repair man, or did you just pick one. If you picked the person, them your stuck with whatever happens next. I from experience where I work, If you went through lg, and problem was not resolved, and could verify that the purchase was made within a year. You would most likely end up with a new fridge from our store, with no cost to you.
Mar 24, 2011 | Heating & Cooling
Water collecting under Cool Select pantry. 3 servicemen attempted to fix it--to no avail. Now water is frozen at front of pantry and still pooled in back. Refrigerator is less than 2 years old. ALSO, a...
Do you have an automatic ice maker/dispenser? If yes check and/or replace same, and also checkfor broken pipes. you may have to slide out fridge to do so....be careful as piping or wiring my also be tangled. look for leaks.Repair as may be necessary. You might also take offthe filter,be sure water is shut off, inject food coloring into the water line,reconnect everything and partially open water and look for colored water which should lead to the leak.
No icemaker? orven as last resort with icemaker, check for hidden built up frost, sometimes a tricky deal and/or turn off fridge completely and let it come to room temp (defrost the whole thing) and see what happens. A collection of new water will inticate that it was over frosted. Probably from too many door openings and closings. Be prepared with cleanup sponges and such! Note: store food properly while defrosting!
Feb 10, 2011 | Refrigerators
Fridge not cooling. Shifted house 2 days back. Before it was alright.
Your fridge systems under chocked. Whenever transport refrigerant unit you should not lift down wards on suction side which will lead compressor oil thr' discharge line. When compressor on, it will pump the oil.It get chocked on filter drier resulting to no cool.
Solution. Remove all gas, and also filter drier. Now flush out condenser side separate and evaporator side separately.Then replace filter drier and vacuum the system.Now do gas charging. Thanks. helpful?
Jan 30, 2011 | LG LRFD25850 French Door Refrigerator
Freezer not as cold after receiver drier filter changed
Needed advise but didn't know I had to pay for information. No Thanks
I managed to solve the problem myself and I will not share with you
TOO BAD
Sep 15, 2009 | Refrigerators
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
Ac capillary tubes
Sounds like you have a clogged cap tube. Yes they should both be sweating, I would expect your low side pressure to be lower though unless it is real hot in the camper. You can replace the tube but make sure what goes in is the same diameter and length because that is all engineered for proper metering into the evaporator.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
I have a frigidaire model FRT21LRGW, the compressor was changed in 2005, evaporator& heat exchanger was changed in jan.2009. Last week apr.2009 the unit started giving problem AGAIN. Freezer and fridge not...
Possible leak in the sealed system. Make sure the technician pressurizes the system with nitrogen, changes drier, evacuates to 500 microns, then weighs in the correct charge.
Apr 23, 2009 | Frigidaire FRS23KF7AB Side by Side...
Auto defrost freezer freezing up. Bottom of fridge not cooling properly
hi! particular insuffcient cooling take place mostly on bottom has under charge refrigerant in the system.clogged filter/drier and loose compression of your compressor.either of this three factor qualified ref/ac technician can do this.
Mar 17, 2009 | Refrigerators
Refrigerators Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
