Battery sign blinking, depending on type of phone, may mean it is charging. If it's NOT charging, you should get a new one ASAP before they are hard to get for the model of your phone! :-) Luck!
There is a link to your printers manual that includes troubleshooting error codes. The blinking exclamation point means that the printers cover is not closed all the way. If there are any other pictures on the printers display that are also blinking like an ink drop or a sun then it can mean something else.
blinking cel on any OBDII vehicle is a warning sign not to drive it-steady light imeans there is a fault or code, but blinking means there is a serious problem and it should not be driven, have the codes read immediately.
hi, i have problem.
my canon pixma mp145 can't operate. the alarm sign is ON and the light for black ink is blinking, and the sign e4 come out . any body can help me what to do?
thanks
rose, malaysia
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual. If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
