Question about Hotpoint NWSR483GBWW Gas Dryer
The egniator looks good , but didn't light, when we put it back in and tried it the circut breaker pops out ?
The A/c and heating unit does not cut on anymore. What could the problem be?
Are you sure you have power? Is it 220? if so double check Circut breaker. If it's popped and pops again when you reset, unplug the unit. Try to reset again, If it pops again when you reset, you have major electrical problem call electrician. If it holds, then you have a major appliance problem that is causing the unit to "pop" the circut breaker. If it's a central unit similar diagnostics, but you can't unplug it. So call your Heating service people. It may just be your thermostat if central system, or more.if the Circut Breaker pops.
Mar 06, 2015 | Heating & Cooling
Gas dryer pops circuit breaker
Number 1 Do NOT! use this dryer until it is fixed, it a a fire hazard. You will need to get the entire power circut checked for shorts. Make sure the motor has been checked under the same conditions as it is used in the dryer, with a capasitor and changing directions etc.
NEVER EVER !!! Change a Circut breaker with a higher value than the one which is there. You will burn the house down. This is a serious fire risk. The power cables over heat and arc then burn, if the breaker is not right.
Feb 01, 2014 | Dryers
Does a 1987 gmcjimmy s-15 have a power window relay ot any relays at all cuz my power windows stoped working it runs a 30 amp circut breaker can the circut breaker go bad?
Anything can go bad, but to my knowledge circuit breakers seldom do. If you have a test light, pull the circuit breaker and probe both terminals for a power signal, with the key on. One terminal should show voltage with key on. If not, check the power distribution box for a blown maxi-fuse, or the wiring from that box to your fuse panel.
BTW, no, no relays are in the window circuit. So if the circuit breaker has power to it, put it back in and check for power on the driver's door master switch-one wire on the master should have voltage with key on. If no hot wire to the master switch, check inside the door openings for a broken wire. If you do have one hot wire there. check the power windows ground-the ground wire for the power windows originates at the master switch and goes back into the cabin to a nearby ground. Put one lead of the test light on the hot wire (key on), and probe the ground terminal at the master switch-if your ground is good, the test light will light up. If the ground is lost, no light. Check for a broken ground wire in the door opening, and/or find the ground and see if it is bad. If the master switch has a hot wire and a good ground wire, replace the master switch.
Apr 25, 2013 | 1987 GMC Jimmy
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
Display says PF, what does that mean
Hello
PF is power failure.Either the reset on the a/c cord has popped out or you may have a thrown circut breaker.
If this has its own reset on the plug try pushing the button back in.
If not check your circut breaker.
Jul 21, 2011 | DeLonghi Heating & Cooling
Last night our power popped off and right back on. Now the fan/lights wont work
check to be sure the breaker in your house panel didn't trip,, turn them off all the way , and back on,, sometimes all or just one will trip, and still look like they are still on
Jul 02, 2011 | Hunter (25417) Ceiling Fan
A/c stops after fuse pulled out then put back in.
Remove the fuse holder for the number 1 A/C and turn it over and put it back in, it's probably upside down.
Sep 09, 2009 | Heating & Cooling
I was changing a light fixture in my bathroom,
hello, all you have to do is to get a new breaker with the same amperage or amp's example 15 amp's of the breaker that's blown and pop out the old one and put in your new one , in the future when working with electricity always manual trip the breaker before working for your safety and the safety of the equipment .good luck
Mar 22, 2009 | Your One Source Homeline Circuit Breaker
Hotpoint NWSR483GBWW Gas Dryer Logo
97 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
