Question about LG LMVM1935 Convection/Microwave Oven
A lot of buttons on the touch control panel dont work. How do I open the front plate?
  • 3 Answers
The front touch plate is a thin membrane which sticks on to the front panel of the microwave. You can not get into it. It has to be replaced as a unit.
Posted on Oct 16, 2010
My Sharp R-240D microwave is flashing 88:88 on the clock. None of the buttons work. How do I get the touch panel to work?
I'm not finding that as a valid US model.
I would suggest checking the label again.
Feel free to contact me directly for more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 02, 2017 | Sharp Microwave Ovens
My microwave LG MB-2341BR is not functioning as the touch panel not working. The start touch is not working. Do we get touch panel replacement now?
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
Jun 16, 2016 | LG Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker 2.0 - black buttons on panel for vent, boost, and light broke . Any way to replace the buttons and take the panel off?
I had the same problem. The front plate is tabbed into place and removes with a flat tip screwdriver and prying in various spots to pop out the tabs. Once the front stainless plate comes off, you need to get behind the black buttons. There is a circuit board behind the buttons, which they make contact with. The problem with mine was the circuit board pushed beyond two metal tabs that keep it in place, so that the buttons were unable to make contact. I used a curved tool to pull the circuit board back forward in front of the tabs and into place. I put the front plate back on and it works like a champ.
Oct 28, 2009 | GE Profile Spacemaker Over-the-Range...
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
Maytag Microwave MMV5207AAQ control problem.
Nuke, Sounds like your touch pad is going south. Why dont you kill the power, drop the control assy. and unplug the ribbon of the control panel to the board. Take an eraser and clean the ends of the ribbon where it connects to the board. Put it back in and see if that made a difference. If not I would suspect it's the touch panel. The part number I have for this is 53001508. Good luck.
May 15, 2006 | Maytag MMV5165 Microwave Oven
LG LMVM1935 Convection/Microwave Oven Logo
153 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
