Question about GoVideo Televison & Video
I have a GO Video Dual VCR - GV3060. I had a power failure and when the power came back on, the power button on the VCR would not turn on the VCR.
  • robertwindle Jun 03, 2008
    Where is the fuse located?
    Genius:
  • 2,035 Answers
First check the fuse ,if blown out replaced it,,,
second the switch may be defective or the cable may be defective
third is power ic may be defective in the unit .
Please connect it other power let and check if it does not power on.Give it to a service center to fix the issue ..........
Posted on Jun 03, 2008
    Master:
  • 351 Answers
Dear robert,
It seems there is problem with your VCR's power section, just check the Fuse if its burnt then change it ,if Fuse is ok then you have to sent this VCR at Authorised Service centre,to rectified this Power Problem.
Regards
    Genius:
  • 3,587 Answers
Sounds like a blown fuse...check that first.
VCR will not play
Since it is a dual DVD/Video player is the Video selected as active? You should have a button switching between DVD and Video!
Nov 02, 2014 | Philips Magnavox DVD/VCR Dual Player
Why wont my vcr turn on?
There is a lot of things that could be causing this. Since this is a unit that is obsolete and no parts are available, it would be a component level service event. IF you have not taken the unit apart to check internal fuses then that is the place to start. Then you look for obvious part failures like burned marks, failed capacitors that have leaked or burst.
Jan 28, 2018 | JVC HR-VP78U VCR
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
How do i set up my old playstation 1???
Connect the cables to the ports on the back of the PlayStation console marked "audio out" and "video out." Make sure to match the same-coloucoloured plugs on the cables and the ports - yellow to yellow, red to red, white to white.
Connect the other ends of the audio/video cables to the ports on the back of the television or VCR marked "audio/video input.
Connect the AC power cord to the PlayStation game console and plug it into a wall socket for power.
Turn on the television, VCR (if included in the connection) and PlayStation console.
Press a button on the remote control to access the audio/video inputs for your television or VCR. The button will be labeled "video," "aux," "auxiliary," "tuner" or "line TV/video." You may need to set your television or VCR to channel 00, 90, 91 or 92. If the remote control does not have the buttons described here, check the product's instruction manual.
Regards.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
We have a Magnavox VCR/DVD player. When pressing the VCR/DVD button it will not switch from VCR to DVD.
I have found this to be a problem with my Magnavox MWD2205. It seems to be a problem that Magnavox (actually FUNAI CORP.) can't seem to understand and fix on their machines.
1. Pick up your remote and press the video button.
2. Press the DVD button.
3. Press the Video button.
4. Press the DVD button.
That simple. This usually works but no guarantee.
Also check on the back of you player and see what cable you have connected. Often times S-Video will be plugged in and so VCR won't function. Or VCR composite video (the little yellow round port) will be plugged in and so your digital DVD won't function either. Make sure that whatever media format you choose that your ports correspond with the chosen format.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Magnavox 2205 DVD/VCR Output Channel Control
1: set tv to channel you want your vcr output to be on. 2: turn vcr on (if it is a vcr/dvd combo make sure it is on vcr) 3: put in video tape. 4: press play button one time, release it, and then press and hold it for three to five seconds. i had to call customer support to figure this out on mine.
Jan 17, 2009 | Philips Magnavox DVD/VCR Dual Player
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Hokk up my dvd player to my digital cable box
Thats ok my family is that same. you have to plug the video cords ( yellow white red ) into the output of the dvd vcr combo ( i think it says vcr output) then connect the ( yellow white and red ) video cord into the input your televition. the input may be at the back or front or both.
It looks better and cleaner if you plug it into the back ones. It should say input and be ( yellow white red ) colours. once you have connected them both up to eachother you turn the power on (if you left it on dont worry its fine) and tuen the vcr on and tv on at the power buttons.
Then turn the tv on to av1 or video what ever your tv calls it. put a vhs or dvd in and press play and it should work.
Thanks for asking if you have any other problems i am happy to help please dont hesitate to ask
Dec 04, 2008 | RCA F32450 32" TV
SAFE
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Aug 12, 2007 | GE VG4060 VCR
Televison & Video Logo
107 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
