Fax machine always saying load a paper,i tried to load a paper ,but the paper always going into different direction? what can i do
    Guru:
  • 832 Answers
Hi there!
the problem is in the feeder, or something that inside would cause the error, you can check the inside for cleaning or call a service center to do the job for you.
regards, fossildude
Posted on Oct 16, 2010
The machine always detect a paper jam without a paper?
Is there a small piece of paper over the paper jam sensor?
Feb 01, 2015 | Office Equipment & Supplies
Paper jam
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Mar 08, 2010 | Brother Fax-1360 Plain Paper Inkjet Fax
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Paper won't load
there is a sensor there it may be bad, look for a small black spring loaded lever where you put the paper in it should go back and say it has paper
unplug ang plug back w/paper in
bad or broken sensor.
Aug 11, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Problems receiving faxes in memory
Just had the same trouble. I loaded paper. Tried more paper, tried less paper. No luck. Finally in deparation and trying "everything" I could think of, I pressed "stop/reset" before pressing "start/copy" and now it's working. Very frustrating!
Aug 30, 2007 | Canon FAXPHONE L80 Laser
jasbo
jasbo
