Question about Viking Microwave Ovens
The turn table does not rotate and it makes a strange noise when it is on. It has never worked properly for the last 3 yrs....in fact you cannot even make popcorn in it....nothing happens
  • Viking Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 16, 2010
Turn table wont turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
I have an Emerson (2 weeks old). It heats well but there is a thumping noise when the table rotates and sometimes the table will operate with a jerking motion.
It sounds like the table is'nt positioned properly on the base it sits on, most are not attached and can be easily removed for cleaning purposes, try repositioning the table on the base.
Mar 10, 2009 | Microwave Ovens
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Loud noise coming from turn table
I have the same problem my microwave is a kenmore this is the second one I've had and they both did it I solved the problem by re-seating the turn table however if you are skilled at taking things apart you can put a few drops of small motor lubricant on the spline it worked for me. good luck!
Nov 21, 2008 | Microwave Ovens
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
194 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
