Question about Maytag Washing Machines
Continuous water - water don't shut off - Maytag Washing Machines
  • 618 Answers
If the taps need to be shut off to stop water flow then the fill valve(what the hoses are connected to) needs to be changed . More then likely someone removed the screens because of poor water flow.
Posted on Oct 16, 2010
Front loading clothes washer digital has continuous cold water flow
Cold water solenoid is not shutting off - ergo a flood of water.
Replace fill valve go to: Search Over 2 1 Million Appliance Parts
Aug 26, 2017 | Coffee Makers & Espresso Machines
How do you set on and off auto
See page 7 on the user manual to set the humidity level and the unit will then operate within the set humidity range. You can also set the timer to make it shut off automatically after a specific time. You may also need to install the continuous drain feature if you do not want to empty the water tank repeatedly.
http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Aug 06, 2014 | Dehumidifiers
I just purchased a used pro source 10 gal. It don't shut off is that normal? I see it says 2.0 continuous. So that mean as long as its on it runs.
The rating of 2.0cfm continuous means that your a/c can produce that much air at certain pressure as long as it runs. It should shut off when it reaches cut-off set pressure. If it does not reach say 125-145 psi and shut off then mostl likely air is leaking from joints or piston/cylinder worn out. Spray soapy water on joints and look at top part of cylinder from under side of pump and look for scratches. If scratched, air is leaking past cyl/piston. Good luck.
Nov 08, 2012 | Air Tools & Compressors
I just recently purchased an air conditioner and I need some help with the installation. In the booklet it says that if you want continuous drainage that you need to have the continuous drainage hose out...
The model you have has an evaporator feature, that normally evaporates the left over condensation. However, there are times that the humidity level may be to high to handle all of the left over condensation. In which case, the pan would need to be drained. In most instances, a plastic low sided container would suffice. But, if you run the AC unit in a continual mode, there's a good chance not all the left over condensation would be evaporated.That's what the hose is for. Not sure why there are 2 of them. Generally there's only one. Anyway, the unit also will shut down automatically, if the pan gets full and needs to be emptied. It will not run until it's emptied. But, I caution you not always rely on that. Anything can go wrong when you're not at home.
Hope this helped you understand how the unit operates. If you have any more questions, call Danby's Customer Support Dept. The 800 number is in your Owner's Manual. They're good folks and will do what's necessary to help you.
Jun 16, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Hi, our recently installed everhot 20 continuous flow is anything but continuous, well, not hot anyway. Sometimes it works fine, other times all we get is cold water that feels like it is starting to get...
If you installed yourself call the support number from the owners manual. If you had a professional do it call them and tell them to fix the issue. This is not normal. If they don' t contact your states contractors license board and get their bondong company info and call the bonding company. When they get that call they will fix it. There are way to many variables to try and TS this issue.
May 13, 2011 | Rheem Water Heaters
Developed hot running water all the time
If the problem is that there is not enough hot water coming out, or when you can not get the hot water to shut off you may need to replace the cartridge inside the faucet.
Jun 26, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Water does not drain thru hose for continuous drainage
water only comes out when you have hi humidity
and will only drain after the unit shuts off
the indoor blower motor makes a vaccuum and holds the water in the drain pan
Sep 11, 2009 | Frigidaire Dehumidifiers
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
How to replace the water valve on a kenmore refigerator
the valve is on the back of the unit where the water come into it. you can temporarly shut the units water off where the water line come out of the wall untill you buy the new solinoids. good luck
Jan 10, 2009 | Kenmore 53642 / 53644 Side by Side...
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
