Question about Frigidaire 31 in. GLEC30S8 Electric Cooktop
I have a frigidaire ceramic cooktop. It started making a "popping noise" and there was a burned smell, but the stove was not on. I had to turn off the breaker to stop this.
    Problem Solver:
  • 7 Answers
Either there's ashort in the stove top or the wiring going to the appliance. Sorry but I would have to see it to see exactly how to fix the problem. the top needs to be removed and inspect the wiring to it. Test the top with a voltmeter forshorts.
Posted on Oct 16, 2010
My Frigidaire stove suddenly makes a noise of ***~~~~ sounds.
Good Afternoon Isaac, thank you for your submission!
I see that your Frigidaire stove is not working but the broil light is on. I would suggest disconnecting power from it for at least ten minutes this is how to perform a factory reset. The factory reset may help clear out any miscommunication within the range and allow it to continue to operate properly. If the reset does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis. I hope the information I have provided is helpful to you. -Matt
Mar 26, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
Radiant cooktop made a pop noise and doesn't work
Your radiant heat element is probably blown. Call kitchenaid for information and replacement part numbers then search online for a good price.
Oct 03, 2012 | KitchenAid KECD867XSS 36" ceramic cooktop
Front burner won't ignite when turned on.
Hello there:
if you Heard or seen this poping you probably have shorted out the ignitor mechanism You can try unplugginh the stove and removing the part and inspecting it and see if it can be cleaned and doubkle check the wiring to see ithatthey are not greasy or there is any buiold up on the wires then reinsert the part and see if it will work now but if not you will have to replave the ignitor ok
If you have a local appliance repair center you should be able to get the part from there if not go online and go to www.repair clinic.com youcan order it from them ok
Hope this is very helpful for you
Best regards MIchael
Mar 13, 2010 | Electrolux Cooktops
Help! My son dropped a bowl on the ceramic cooktop of our range
Hi, if you still have this stove can you please contact me? Thanks so much!
Mar 24, 2009 | GE 30 in. JP340 Electric Cooktop
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire 31 in. GLEC30S8 Electric Cooktop Logo
312 people viewed this question
Top Frigidaire Cooktops Experts
Oloyede Monsuru
ray gallant
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
