Question about Maytag Dryers
Maytag dryer LDE512, 20 years old. Buzzer is stuck and won't turn off when door is shut....
  • 618 Answers
Motor centrifugal switch may be stuck. End of motor where switch is may be full of lint
Posted on Oct 16, 2010
  • ddlpsreid Oct 17, 2010
    thank you ! Would this also be causing the start switch to remain on without having to be depressed to turn on when door is opened then closed?
  • Alf Hopkins
    Alf Hopkins Oct 18, 2010
    Perhaps but now that you mention that it could possibly be that the start switch is stuck. To test this remove one of the wires from the push (start) switch. Make sure it is touching nothing and plug the dryer back in. If the buzzer is not sounding replace the start switch. If the buzzer still sounds and the dryer starts up it is likely the motor switch.
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
I have a Maytag dryer (Model MDE2600)and the buzzer will not go off unless the door is opened. Buzzer begins when door is closed.
Hi
Buzzer comes on because the control senses that the door is not closed and won't start the cycle. This issue is caused by door switch-latch assembly (part#6 and part#9 in this diagram) that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | Maytag Dryers
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Feb 18, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Buzzer will not shut off when load is done
If your dryer also starts without pressing the start switch, then the push to start switch
contacts are stuck in the closed position. Sometimes you can press the button on-off-on-off
quickly to unjam the contacts, otherwise replace switch.
Jan 12, 2009 | Maytag Dryers
Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Aug 02, 2008 | Maytag Dryers
Dryers Logo
231 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
