Question about Cisco 2106 (AIR-WLC2106-K9)
Enter User Name (or 'Recover-Config' this one-time only to reset configuration t o factory defaults) User: Warning! Software watchdog on task pemReceiveTask expired, raise its prior ity! 1557 - TaskID 154205984 ('pemReceiveTask') osapi_prio 240 old_prio 240 pthread_prio 7 cur_prio 7 tickleTimer 0 1589 - TaskID 154205984 ('pemReceiveTask') osapi_prio 45 old_prio 240 pthread_prio 81 cur_prio 81 Error! Software watchdog on task pemReceiveTask expired! Reaper Reset: Task "pemReceiveTask" missed software watchdogReaper is kickin' in to high gear Task pemReceiveTask is consuming 0% CPU! (0% user, 0% system) 1557 - TaskID 154205984 ('pemReceiveTask') osapi_prio 45 old_prio 240 pthread_prio 81 cur_prio 81 tickleTimer 0 1589 - TaskID 154205984 ('pemReceiveTask') osapi_prio 240 old_prio 240 pthread_prio 7 cur_prio 7 Task pemReceiveTask is consuming 0% (0% user, 0% system) Stackdump from pemReceiveTask Frame 0: 0x08051d72: sighup_handler+42 Frame 1: 0x4018608c: ssh_ldap_client_enable_tls+932996688 Frame 2: 0x401bf950: ssh_ldap_client_enable_tls+933232404 Frame 3: 0x0825f9f9: hapiBroffuSendIoctl+613 Frame 4: 0x08250fae: dapiCtl+1106 Frame 5: 0x081baf2e: dtlBsnFdbMacAddrDelete+278 Frame 6: 0x082cc129: pemDelScb+269 Frame 7: 0x082cc7d9: pemReceiveTaskEntry+301 Frame 8: 0x081f8ffd: osapiErrnoGet+405 Frame 9: 0x40183040: ssh_ldap_client_enable_tls+932984324 Frame 10: 0x40262cfa: ssh_ldap_client_enable_tls+933900990 ************************************************************ * Start Cisco Crash Handler * ************************************************************ Version: 4.0.217.0 Timestamp: Fri Oct 15 22:39:33 2010 pid: 141 TID: 37925 Task Name: pemReceiveTask Reason: Reaper Reset timer tcb: 0xd timer cb: 0x814b9c0 ('rrmSendTimerMsg+224') timer arg1: 0xac3269c timer arg2: 0x0 ------------------------------------------------------------ Analysis of Failure: Software was stopped by the reaper for the following reason: Reaper Reset: Task "pemReceiveTask" missed software watchdog ------------------------------------------------------------ System Stack Frame 0: 0x08051d72: sighup_handler+42 Frame 1: 0x4018608c: ssh_ldap_client_enable_tls+932996688 Frame 2: 0x401bf950: ssh_ldap_client_enable_tls+933232404 Frame 3: 0x0825f9f9: hapiBroffuSendIoctl+613 Frame 4: 0x08250fae: dapiCtl+1106 Frame 5: 0x081baf2e: dtlBsnFdbMacAddrDelete+278 Frame 6: 0x082cc129: pemDelScb+269 Frame 7: 0x082cc7d9: pemReceiveTaskEntry+301 Frame 8: 0x081f8ffd: osapiErrnoGet+405 Frame 9: 0x40183040: ssh_ldap_client_enable_tls+932984324 Frame 10: 0x40262cfa: ssh_ldap_client_enable_tls+933900990 ------------------------------------------------------------ Stacks from all busy tasks Task pemReceiveTask is consuming 0% (0% user, 0% system) Stackdump from pemReceiveTask Frame 0: 0x08051d72: sighup_handler+42 Frame 1: 0x4018608c: ssh_ldap_client_enable_tls+932996688 Frame 2: 0x401bf950: ssh_ldap_client_enable_tls+933232404 Frame 3: 0x0825f9f9: hapiBroffuSendIoctl+613 Frame 4: 0x08250fae: dapiCtl+1106 Frame 5: 0x081baf2e: dtlBsnFdbMacAddrDelete+278 Frame 6: 0x082cc129: pemDelScb+269 Frame 7: 0x082cc7d9: pemReceiveTaskEntry+301 Frame 8: 0x081f8ffd: osapiErrnoGet+405 Frame 9: 0x40183040: ssh_ldap_client_enable_tls+932984324 Frame 10: 0x40262cfa: ssh_ldap_client_enable_tls+933900990 ------------------------------------------------------------ Semaphore and Mutex Usage Mutex 'sshpmTftpRuleSemaphorePtr' @ 0xaa33f1c Created fp_main_task(sshpm.c:3 66) Locked by sshpmReceiveTask(sshpmrecv.c:958) 0 tasks waiting for resource. Stackdump from sshpmReceiveTask Frame 0: 0x08051d72: sighup_handler+42 Frame 1: 0x4018608c: ssh_ldap_client_enable_tls+932996688 Frame 2: 0x401bf950: ssh_ldap_client_enable_tls+933232404 Frame 3: 0x401858cd: ssh_ldap_client_enable_tls+932994705 Frame 4: 0x401820a9: ssh_ldap_client_enable_tls+932980333 Frame 5: 0x0857db0e: d_async_queue_pop+58 Frame 6: 0x081f5bc4: osapiMessageReceive+32 Frame 7: 0x0819d444: sshpmReceiveTaskEntry+644 Frame 8: 0x081f8ffd: osapiErrnoGet+405 Frame 9: 0x40183040: ssh_ldap_client_enable_tls+932984324 Frame 10: 0x40262cfa: ssh_ldap_client_enable_tls+933900990 ------------------------------------------------------------ Memory Information System Memory Information: Total System Memory: 256724992 bytes (244.84 Mb) Used System Memory: 108687360 bytes (103.65 Mb) Free System Memory: 148037632 bytes (141.18 Mb) Heap information: Bytes alloced from RTOS: 2598316 bytes (2.47 Mb) Chunks free: 14 bytes Number of mmapped regions: 21 Total space in mmapped regions: 17801216 bytes (16.97 Mb) Total allocated space: 2565284 bytes (2.44 Mb) Total non-inuse space: 33032 bytes (32.25 Kb) Top-most, releasable space: 22568 bytes (22.03 Kb) Total allocated (incl mmap): 20399532 bytes (19.45 Mb) Total used (incl mmap): 20366500 bytes (19.42 Mb) Total free (incl mmap): 33032 bytes (32.25 Kb) Buffer Pooled Malloc Usage Pool[00]: 16 byte chunks chunks in pool: 800 chunks in use: 653 bytes in use: 10448 bytes requested: 7022 (3426 overhead bytes) Pool[01]: 64 byte chunks chunks in pool: 700 chunks in use: 560 bytes in use: 35840 bytes requested: 17042 (18798 overhead bytes) Pool[02]: 128 byte chunks chunks in pool: 900 chunks in use: 821 bytes in use: 105088 bytes requested: 61879 (43209 overhead bytes) Pool[03]: 256 byte chunks chunks in pool: 200 chunks in use: 89 bytes in use: 22784 bytes requested: 16261 (6523 overhead bytes) Pool[04]: 1024 byte chunks chunks in pool: 300 chunks in use: 242 bytes in use: 247808 bytes requested: 95855 (151953 overhead bytes) Pool[05]: 2048 byte chunks chunks in pool: 100 chunks in use: 33 bytes in use: 67584 bytes requested: 38852 (28732 overhead bytes) Pool[06]: 4096 byte chunks chunks in pool: 50 chunks in use: 38 bytes in use: 155648 bytes requested: 110254 (45394 overhead bytes) Max number of Mbufs: 1536 number of Mbufs Free: 1531 number of Mbufs In Use: 5 ------------------------------------------------------------ Interrupt Status Name Total Interupts PerSecond 0: Misc 90153 100 4: q 208 0 7: q 7 0 11: q 26247 30 14: q 2092 0 ------------------------------------------------------------ Message Logs Fri Oct 15 22:29:22 2010 [ERROR] spam_lrad.c 13270: Unable to send Delete-Mobil e request to unknown AP 00:1e:7a:70:2e:d0 Fri Oct 15 22:29:04 2010 [ERROR] spam_tmr.c 565: Did not receive hearbeat reply from AP 00:1e:7a:a8:5f:d0 Fri Oct 15 22:29:03 2010 [ERROR] spam_tmr.c 565: Did not receive hearbeat reply from AP 00:1f:9e:80:e1:90 Fri Oct 15 22:29:02 2010 [ERROR] spam_tmr.c 565: Did not receive hearbeat reply from AP 00:1e:7a:70:2e:d0 Fri Oct 15 22:26:34 2010 [ERROR] spam_lrad.c 1897: AP 00:1e:7a:a8:5f:d0 associa ted. Last AP failure was due to Link Failure, reason: ECHO_REQUEST Fri Oct 15 22:25:38 2010 [ERROR] apf_utils.c 193: Missing Supported Rate. Fri Oct 15 22:25:34 2010 [ERROR] spam_lrad.c 1897: AP 00:1f:9e:80:e1:90 associa ted. Last AP failure was due to Link Failure, reason: ECHO_REQUEST Fri Oct 15 22:25:33 2010 [ERROR] spam_lrad.c 1897: AP 00:1e:7a:70:2e:d0 associa ted. Last AP failure was due to Link Failure, reason: ECHO_REQUEST Fri Oct 15 22:25:14 2010 [ERROR] sshpmrules.c 3053: SSHPM: attempting to enable secure shell access when already enabled. Fri Oct 15 22:25:14 2010 Previous message occurred 3 times Fri Oct 15 22:25:11 2010 [ERROR] dtl_data.c 258: dtl_data.c 258: In dtlDataLowT ask_rxBroffPkt call to 'dtlPduReceive' failed Fri Oct 15 22:25:11 2010 [ERROR] dtl_data.c 258: dtl_data.c 258: In dtlDataLowT ask_rxBroffPkt call to 'dtlPduReceive' failed Fri Oct 15 22:25:11 2010 Previous message occurred 2 times Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1581: Unable to set uranium QOS Pro file ACM Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1588: Unable to set platinum QOS Pr ofile ACM Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1581: Unable to set platinum QOS Pr ofile ACM Fri Oct 15 22:25:03 2010 Previous message occurred 2 times Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1581: Unable to set gold QOS Profil e ACM Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1588: Unable to set bronze QOS Prof ile ACM Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1581: Unable to set bronze QOS Prof ile ACM Fri Oct 15 22:25:03 2010 Previous message occurred 2 times Fri Oct 15 22:25:03 2010 [ERROR] sim_util.c 1581: Unable to set silver QOS Prof ile ACM Fri Oct 15 22:25:03 2010 [CRITICAL] timerlib.c 442: Task 154182432 unable to ac quire timer lock. Fri Oct 15 22:25:03 2010 [CRITICAL] osapi_sem.c 777: osapiBsnTimerCreate() @ ti merlib.c:442: ERROR: 'timerSema' is a NULL pointer. Fri Oct 15 22:25:02 2010 [CRITICAL] timerlib.c 442: Task 154182432 unable to ac quire timer lock. Fri Oct 15 22:25:02 2010 [CRITICAL] osapi_sem.c 777: osapiBsnTimerCreate() @ ti merlib.c:442: ERROR: 'timerSema' is a NULL pointer. Fri Oct 15 22:25:02 2010 [CRITICAL] bootos.c 836: Starting code... ************************************************************ * End Cisco Crash Handler * ************************************************************ Cisco Crash Handler This build was configured to copy this crash information to a file called: "/mnt/application/mwar_dump1.crash" CISCO SYSTEMS Embedded BIOS Version 1.0(12)6 08/21/06 17:26:53.43 Low Memory: 632 KB High Memory: 251 MB PCI Device Table. Bus Dev Func VendID DevID Class Irq 00 01 00 1022 2080 Host Bridge 00 01 02 1022 2082 Chipset En/Decrypt 11 00 0C 00 1148 4320 Ethernet 11 00 0D 00 177D 0003 Network En/Decrypt 10 00 0F 00 1022 2090 ISA Bridge 00 0F 02 1022 2092 IDE Controller 00 0F 03 1022 2093 Audio 10 00 0F 04 1022 2094 Serial Bus 9 00 0F 05 1022 2095 Serial Bus 9 Evaluating BIOS Options ... Launch BIOS Extension to setup ROMMON Cisco Systems ROMMON Version (1.0(12)7) #2: Fri Oct 13 10:52:36 MDT 2006 Platform AIR-WLC2106-K9 Launching BootLoader... Cisco Bootloader (Version 4.0.191.0) .o88b. d888888b .d8888. .o88b. .d88b. d8P Y8 `88' 88' YP d8P Y8 .8P Y8. 8P 88 `8bo. 8P 88 88 8b 88 `Y8b. 8b 88 88 Y8b d8 .88. db 8D Y8b d8 `8b d8' `Y88P' Y888888P `8888Y' `Y88P' `Y88P' Booting Primary Image... Press now for additional boot options... Detecting hardware . . . . Cisco is a trademark of Cisco Systems, Inc. Software Copyright Cisco Systems, Inc. All rights reserved. Cisco AireOS Version 4.0.217.0 Initializing OS Services: ok Initializing Serial Services: ok Initializing Network Services: ok Starting ARP Services: ok Starting Trap Manager: ok Starting Network Interface Management Services: ok Starting System Services: ok Starting Fast Path Hardware Acceleration: ok Starting Switching Services: ok Starting QoS Services: ok Starting FIPS Features: Not enabled Starting Policy Manager: ok Starting Data Transport Link Layer: ok Starting Access Control List Services: ok Starting System Interfaces: ok Starting Management Frame Protection: ok Starting LWAPP: ok Starting Crypto Accelerator: Not Present Starting Certificate Database: ok Starting VPN Services: ok Starting Security Services: ok Starting Policy Manager: ok Starting Authentication Engine: ok Starting Mobility Management: ok Starting Virtual AP Services: ok Starting AireWave Director: ok Starting Network Time Services: ok Starting Cisco Discovery Protocol: ok Starting Broadcast Services: ok Starting Power Over Ethernet Services: ok Starting Logging Services: ok Starting DHCP Server: ok Starting IDS Signature Manager: ok Starting RFID Tag Tracking: ok starting TSM: ok Starting CIDS Services: ok Starting Ethernet-over-IP: ok Starting Management Services: Web Server: ok CLI: ok Secure Web: ok (Cisco Controller) Enter User Name (or 'Recover-Config' this one-time only to reset configuration t o factory defaults)
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
  • 53 Answers
SOURCE: Can't get an IP address over time.
Ok I have guessed a couple of things. Here goes.
the version of software 12.4 (3g) is very old
I think that you have DHCP configured on the AP
the cisco site lists loads of issues regarding DHCP and memory leaks in numerous guises with not only your IOS version but newer versions too.
the reason why I have homed in on this is that you say that the unit works for about a week then essentially stops until you reboot the AP. (I guess that you do this by power cycling not by issuing the reload command) in the short term you have fixed the problem.
I would suggest that you upgrade the IOS to something newer. the current version listed is 12.4(22)T if it's of any help.
lastly as you know when the system actually goes wrong. You are able to issue the reload command with additional settings so it could reload @ X date and time if NTP is configured or you can specify a time duration in minutes if preferred.
I can't think of anything else I afraid.
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: ''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
Posted on Jun 02, 2009
Uberhax
  • 13 Answers
SOURCE: How to reset c2106 to factory defaults?
do you have a little button behind it ?if you do tap it for 20 seconds.
Posted on Feb 25, 2010
  • 21 Answers
SOURCE: I forget to change the
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Posted on Dec 25, 2010
How do I get my password?
If you've forgotten the password to your Netgear router, then you're locked out from making any changes. The only way to recover a Netgear router password is to reset the device to factory default settings. You can then set a new password and recover your ability to configure the router.
Other People Are Reading
"" frameborder="0" marginwidth="0" marginheight="0" scrolling="no" style="border: 0px currentColor; border-image: none; vertical-align: bottom;"> 22Instructions
    • 1 Use a pen or paper clip to press the reset button on the back of the Netgear router. Keep the button pressed until the lights in the front of the router start flashing. The router will reboot after resetting itself.
    • 2 Open a browser window and enter the IP address of the Netgear router to access the configuration console. The Netgear default IP address is 192.168.0.1.2
    • 3 Enter the default username and password, as follows:
      username: admin
      password: 1234 or password
    • 4 If you are still unable to log in, the router may not have been reset. Unplug the router and hold the reset button for 20 seconds before plugging in the power cord. Repeat Steps 2 and 3 to gain access to the route
Jun 26, 2014 | NetGear Computers & Internet
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
How do i reset my at-8000s switch to factory default by using command
follow this step
KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
Delete startup-config [y/n]? y
Startup file was deleted
KIMIA#
User Name:manager
Password:friend
console#
console#
Mar 29, 2012 | Allied Telesyn Allied Telesis...
I need my d-link wireless password to connect to an I pod touch, I had it written down but it must be wrong and the touch wont recognize the wireless.
If you don't remember the password for your wireless you will need to do a hard reset on the router and restore it back to factory defaults.
Press and hold the reset button at the back for 30 seconds. The router will reboot and you should be able to login to the config page at http://192.168.0.1 with the user name "admin" and no password
Amardeep
For more tips, visit my blog at http://thegeektweet.wordpress.com
May 27, 2011 | D-Link Computers & Internet
I have forgoten my password. plz help me to get it reset
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 22, 2011 | Computers & Internet
How i get my netgear name and webkey i had it wrote down but lost it?
The only way to recover a password is to reset the router to Factory Default.
To do this:
Use a paper clip or something small and hold the reset button on the back for 10-12 seconds. (WARNING! this will remove all settings and bring it back to the factory default, you will have to re-configure the router.)
Once defaulted, enter admin for the username and password for the password.
Dec 22, 2010 | NetGear WGR614 Wireless Router
I forgot my user name and password on my router. how do I reset router and log back in using the default password? Ans what is the default user name and password
In case you have forgotten the password of your router, there is no way to recover it back.
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory settings by pressing the reset button on the back side of the router. Press the button for a few seconds, the lights on the front would blink and the router would restart with factory settings. Please note that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE ALL NETWORK CONFIGURATIONS AND SETTINGS ALL OVER AGAIN
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 21, 2010 | AT&T 6850G Router (ALL07735)
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Forgot factory default name and password for my Pansonic BL-C131
There's a reset button. It'll clear the user config. There is no default account.
May 10, 2009 | Panasonic BL-C131 Network Camera
Cisco  2106 (AIR-WLC2106-K9) Logo
612 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
