Question about Panasonic Matshita- | UJ-845-B | USB 2.0 | DVD-+RWRAMDL (GPUJ845BU) Burner
Computer is a Sony Vaio VGN-TT46MG - an 11" screen and Matshita DVD-RAM UJ892AS drive. The drivers are correct and loaded correctly. The registry settings have been reported as being incorrect/incomplete. I can not even get the DVD drive to open with the manual button on the computer! Does anyone have the registry settings for this DVD?
  • 2 more comments
  • kooka377 Oct 16, 2010
    It is a Sony Vaio computer - not Panasonic! The drive is a Matshita DVD-RAM UJ-892-AS.
    I have installed the drivers; the device page is showing the drivers running correctly. An update returns that the drivers are the latest.
    Three different driver update programs (Driver Robot, Driver Detective & Driver Scanner), all show that the drivers are correct and loaded correctly.
    I had one instance of a message from Win 7, that the registry settings for the DVD were corrupted.
    If I can get the settings that are correct, I can do a comparrison check ...... and change them if required.
    If you have a set of drivers, send them to me and I will re-install them.
    If I press the external eject button on the front right edge of the Vaio laptop, I get the message -
    "Cannot open the tray of the optical drive."
    Any further ideas? Please send me some drivers!
    Cheers,
    Alan.
    Drive is connected correctly!
    Msg 1.
    Msg 2.
    Cheers,
    Alan.
    Hi elix0411,
    Thank you - problem solved.
    An easy fix when you find someone who knows the "correct stuff".
    Once again, thank you.
    Cheers,
    Al.
  • 3,530 Answers
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
5. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
6. Quit Registry Editor, and then restart the computer.
And another way is to make sure you have correctly inserted the IDE and Power Cables.
Thank you for using Fixya!
Posted on Oct 16, 2010
  • Jose Cada
    Jose Cada Oct 16, 2010
    Happy to have helped you kooka377 :)
  • 1,188 Answers
No one will have the "registry settings" for your computer. All you need is the drivers for the system. When Windows is installed, the registry is developed, nothing to worry about as far as "registry settings." Just drivers and your set.
  • EJ Kudelka
    EJ Kudelka Oct 16, 2010
    Also, if the DVD drive will not open at all, it is probably not corrected properly. Check the connecting wires for the drive internally. The wire has 4 pins and has black, red, and yellow wires in the connector.
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have an Asus laptop with matshita dvd ram uj892as and when I put someone dvd or cd, noise, but nothing happens.. i need help! thank you!
You need to go to device manager and pull up the properties for the DVD drive and choose the "Region" that you are in. After that the drive should work.
Aug 18, 2010 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Uninstalled matshita dvd-ram uj-8505 ata device
Go to Control Panel, Add Hardware and Windows should do it for you.
If you are PC literate go to Start click on it go to My Computer nad right click on ot go to Hardware and click on it go to Device Manager and click on that scroll down to CD/DVD and click on that select the DVD unit and select update driver
Jan 14, 2010 | Sony VAIO VGN-N365E/B Notebook
Matshita DVD driver
I found this site works for many people www.driverguide.com you might have to register but well worth it and you will end your search within 2 mins. Otherwise seek it out www.sony.com under support..
Thanks
Sep 17, 2009 | Sony VAIO VGN-FS980 Notebook
My matshita dvd-ram uj880es driver has a code 39 ,
Start>run>type in "regedit"
go to:
HKEY_LOCAL_MACHINE>SYSTEM>>current cotrol set>control>class>{4d36E965-E325-11CE-BFC1-08002BE10319}
go ahead and delete the following,
upperFilters
LowerFileters
UpperFilters.bak
LowerFilters.bak
delete them, exit registry, restart and see if that fixes it.
(Remember to always back up your registry, and files when ever messing with the registry).
Aug 17, 2009 | Toshiba Satellite L305-S5907 Laptop
Matshita DVD-Ram UJ870QJ
i have sony vaio vgncr353 L n my dvd r/w is not working properly.
my vaio have matshita dvd ram uj870qj ata device n read and write cds n reads burned dvds but cant burns blank dvds.. so pls solve my problem.. quickly
Jul 23, 2009 | Sony Computers & Internet
Matshita uj850s dvd/cd drive plays dvds but not cds, help!
try to delet the lower and upper case in the registry. Visit Microsoft.com and search for DVD/cd not detected and follow the steps.
Please vote, Thanks!
Jun 27, 2009 | Sony VAIO VGN-N320E Notebook
Unable to burn DVD
Its purely the DVD fault.
Try using a different brand dvd disk.
May 12, 2009 | Computers & Internet
Matshita UJ-840D cannot be connected/found
Tried this on my Sony Vaio VGN-SZ650N after completely reinstalling Windows Vista on it and losing access to my this drive. It worked. :)
http://support.microsoft.com/kb/929461
Good luck hope this helps,
ArcheantusAlive
Mar 14, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Computers & Internet Logo
686 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
