Question about Lincoln Pro Cut 55
Was cutting with a pro cut 55 hooked to our plasma cam machine it stopped cutting and all the lights are flashing on it and now wont reset or nothing
3 Suggested Answers
  • 59 Answers
SOURCE: problems with Lincoln LINCOLN ELECTRIC K1756-1
Try using fine sand paper and clean the tip of electrode and the thing that looks like thimble, another solution was don't tighten tip cover too much back off a little til you ge good contact. some units don't like to be clicked ON without making contact with working metal, you may get two or three clicks and then nothing til the air stops flowing.
Posted on Feb 06, 2010
smitty5609
  • 243 Answers
SOURCE: Lincoln Pro Cut 20 cuts about 2 seconds then
Is your ground good?
Posted on Sep 24, 2011
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
(From: https://app.aws.org/forum/topic_show.pl?tid=31328)
"Remember, they are a drag machine up to about 3/8" thick material. Keep the power down as low as possible for the material being cut. Keep the right air filters on to supply clean air. Keep the air pressure between 60 (min or it will shut down) and 70 for most applications (more is not better-just like oxygen on the torch or air to an air-arc).
Also, check that the air hose hasn't come loose from the gun.
That was Brian's problem from YouTube (http://www.fixya.com/answer/answerpageslideview.aspx?thid=26182813&ctg=373&brd=5236)
May 02, 2016 | Lincoln Welding Tools
Green light flashes
always remember the ground...
have a big air supply. small compressors can not keep up and machine stops cutting.
Nov 24, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
The gas light come on and flashes and wont cut. I have changed all the nozzels on the torch and still nothing?
Hi:
Gas light goes on when you have an air flow or pressure problem. Do you have enough pressure? you will need at least 120 psi at the compressor and 75psi at the plasma machine. Do you have enough flow? You will need 20 SCFH and a 30 gallon compressor reserve tank.
Let me know if this help. Please vote.
Jul 30, 2011 | RTO Esab Power Cut 1250 Plasma W/Pt 32EH...
The safety light on the Pro cut 55 will not stop flashing
alot of times the torch can be clogged up and that will make it come on
Apr 20, 2010 | Lincoln Procut 55 208/230/460/1/3/60 50Ft...
Problems with Lincoln LINCOLN ELECTRIC K1756-1 PRO-CUT 25 PLASMA: all settings ok, air ok will spark on occassion and then nothing. tried everything put will only lit very seldom and then nothing.????...
Feb 03, 2010 | Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA...
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to gun.red safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Jan 22, 2009 | Hobart Welding Tools
Safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Nov 26, 2008 | Lincoln Pro Cut 55
Lincoln Pro Cut 55 Logo
70 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
