Question about Petzl Camping, Backpacking & Hiking
I replaced bat. and it just stopped working as if bat. r no good, but they are new. Tjhe indicator light does not light up
2 Suggested Answers
  • 619 Answers
SOURCE: bat indicator blinkĀ“s
Hi , clean the battery terminal having acid rust to contact will positive and nigative terminal.Open the lense to release the shutter miror might open , check the camera option select in auto or manual not in lower speed can cause stuck.open the film compartment and load film .
Posted on Feb 28, 2008
95 dodge dakota.lost lights while driving.r/r switch.stopped running heater blower.no blinking lights.I lost my dash lights.and the dome light dont work.this could use some attention.thanks
sounds like your main fuse or fuse link has blown---something directing your power from the bat to system has been compromised---you'll need to systematically check your wiring including (most important) your grounds---you may have a wire that has corroded internally breaking the connection-GL
Nov 29, 2017 | Dodge Cars & Trucks
Daytime running lights wont shutoff already replaced switch no help
-If there is a day light running relay. The relay stuck contact.
-Here is a basic to check.
-Turn off the engine and if the light still on. Then try to unplug
each relay. The one you unplug and the light is off. That is the bad one.
-Before replace it. Use different one but same rat from different location to plug in that, if the light is still off then you need new one.
Good luck
Mai
Aug 19, 2015 | Cars & Trucks
Model sc50 has new batteries. horn works, bat condition indicator works. no LED light and unit will not drive. have reset and checked drive lever is in drive. what to look for now?
hi take the key out put lever in free wheel then put lever in drive put key back ..if the circuit is similar as the pride xl it should work ....good luck
Sep 25, 2014 | Pride Health & Beauty
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
Fog lights stop working
There is no provision for fog lights in your vehicle.
Mar 27, 2017 | 2001 Jeep Wrangler
While driving to work lights went out and when I pulled over and accelerated slightly they came back on, but indicator on dash that shows little engine came on as well. I tried tightening the gas cap...
sounds like alternator may be going out i had same problem disconnect possitive side bat terminal while car running if dies out replace alternator good luck
Jan 21, 2010 | 2002 Honda Civic
Just installed a new alternater and the battery gadge is reding discharge I had the battery checked and its good. Can you help
Check the 'Bat' / 'Charge'/ 'Alt' indicator on the dash panel lights when the vehicle ignition is switched on prior to starting the engine.
This indicator should extinguish within approx 1 second of starting engine.
If the indicator is not operating the alternator cannot provide charge current - check:-
1) the wiring connections to the new alternator,
2) the indicator lamp is not blown,
3) the alternator is properly grounded.
If the indicator light works normally, check the output voltage of the alternator is approx 14.5v when the motor is running.
If its about 14.5v, the battery should be charging.
Aug 12, 2009 | 2003 Chevrolet Tahoe
Dash board lights on grand voyager flashing when engine on. car would not start so charged bat over night. Then bought a new bat. have changed battery and still happening. Did altinator test lights dipped...
the controls always click when you change the setting as it is electronic, don't panic, but you should ask your ex as he is well up in voyager' s and the back seat not folding down properly!!!!!
Jun 20, 2009 | 2000 Chrysler Grand Voyager
Camping, Backpacking & Hiking Logo
Top Petzl Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
