Question about Samsung SGH-E880 Cellular Phone
I want e880 strip connector - Samsung SGH-E880 Cellular Phone
I have forget my e880 pasword.please tell me reset code
unfortunately this is going to require a full factory default reset. so dial through everything and write your settings down.
http://www.icom.co.jp/world/support/download/manual/pdf/ID-E880_0b.pdf
Feb 19, 2015 | Icom ID-E880 Dual Band Digital Mobile...
Qmobile e880 hard reset
sir not cell phone but tata docomo dongal not cont
Oct 13, 2013 | Cell Phones
Q mobile E880 wifi
Dear sir,
kindly plz how to Remove Qmobile E880 Wifi
(not enough Mamory ) Problem
Jul 17, 2013 | Cell Phones
Fussable link removal
To repair any blown fuse link use the following procedure:
  1. Disconnect the negative battery cable.
  2. Cut the damaged fuse link from the wiring harness and discard it. If the fuse link is one of three circuits fed by a single feed wire, cut it out of the harness at each splice end and discard it.
  3. Identify and procure the proper fuse link with butt connectors for attaching the fuse link to the harness.
  4. To repair any fuse link in a 3-link group with one feed:
    1. After cutting the open link out of the harness, cut each of the remaining undamaged fuse links close to the feed wire weld.
    2. Strip approximately 1 / 2 in. (13mm) of insulation from the detached ends of the two good fuse links, Then insert two wire ends into one end of a butt connector and carefully push one stripped end of the replacement fuse link into the same end of the butt connector and crimp all three firmly together.
Care must be taken when fitting the three fuse links into the butt connector as the internal diameter is a snug fit for three wires. Make sure to use a proper crimping tool. Pliers, side cutter, etc. will not apply the proper crimp to retain the wires and withstand a pull test.
    1. After crimping the butt connector to the three fuse links, cut the weld portion from the feed wire and strip approximately 1 / 2 in. (13mm) of insulation from the cut end. Insert the stripped end into the open end of the butt connector and crimp very firmly.
    2. To attach the remaining end of the replacement fuse link, strip approximately 1 / 2 in. (13mm) of insulation from the wire end of the circuit from which the blown fuse link was removed, and firmly crimp a butt connector or equivalent to the stripped wire. Then, insert the end of the replacement link into the other end of the butt connector and crimp firmly.
    3. Using rosin core solder with a consistency of 60 percent tin and 40 percent lead, solder the connectors and the wires at the repairs then insulate with electrical tape or heat shrink tubing.
Heat shrink tubing must be slipped over the wire before crimping and soldering the connection.
  1. To replace any fuse link on a single circuit in a harness, cut out the damaged portion, strip approximately 1 / 2 in. (13mm) of insulation from the two wire ends and attach the appropriate replacement fuse link to the stripped wire ends with two proper size butt connectors. Solder the connectors and wires, then insulate.
  2. To repair any fuse link which has an eyelet terminal on one end such as the charging circuit, cut off the open fuse link behind the weld, strip approximately 1 / 2 in. (13mm) of insulation from the cut end and attach the appropriate new eyelet fuse link to the cut stripped wire with an appropriate size butt connector. Solder the connectors and wires at the repair, then insulate.
  3. Connect the negative battery cable to the battery and test the system for proper operation.
Do not mistake a resistor wire for a fuse link. The resistor wire is generally longer and has print stating, "Resistor-don\'t cut or splice\'\'.
When attaching a single No. 16, 17, 18 or 20 gauge fuse link to a heavy gauge wire, always double the stripped wire end of the fuse link before inserting and crimping it into the butt connector for positive wire retention.
May 04, 2013 | Cars & Trucks
I Want to Reset My Qmobile E880
my q is, E880 per opera mini kasy download kary gy?
Mar 23, 2013 | Cell Phones
Samsung e880 battery required in delhi
hi,
ship online for the battery at www.ebay.in
I hope this is helpful to you.
Thanks
May 14, 2010 | Samsung SGH-E880 Cellular Phone
Format code of sgh-e880 cellular phone
try some of these
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# Software Version
*#2222# Hardware Version
*#1234# Firmware Version
*#92782# WAP User Agent
*#927827# WAP WAProfile
*#0228#/*#9998*228# Battery profile
* # 0842 # Vib test
* # 0746 # SSMS MEMORY
* # 0638 # SIM SIM network ID
* # 0778 # SST Sim service Table
* # 0289 # Buz test
* # 0782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*228 # Battery Profile
* # 9998*842 # Vib test
* # 9998*746 # SSMS MEMORY
* # 9998*638 # SIM SIM network ID
* # 9998*778 # SST Sim service Table
* # 9998*289 # Buz test
* # 9998*782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*968 # YAMAHA OF OK ONE
* # 9998*76 # Product NUMBER
* # 9998*377 # error memory
* # 9998*5646 # GPRS Logo
Code, whose effect and/or function I exactly do not point
* # 9324 # monitor? (with the red key velassen)
* # 32436837 # DAI ON?
* # 22766 # Automatically Recive call?
* # 227633 # manual Recive call?
!!! RESET code!!!
!!! these codes use only if you know which it does!!!
!!! Thus data in the Handy are deleted!!!
* 2767*3855 # FULL RESET
* 2767*2878 # CUST RESET
* 2767*927 # WAP RESET
* 2767*667 # MMS RESET
* 2767*36245 # email RESE
Jun 25, 2008 | Samsung SGH-E880 Cellular Phone
Samsung SGH-E880 Cellular Phone Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
