I have a RCA RC27A remote for a converter box w/an Orion tv...the volume & power to the tv no longer works w/this remote. The other functions on the remote pertaining to tha box works but not to the tv all of a sudden. How do I reprogrãm this remote to work w/the tv again?
    Genius:
  • 1,126 Answers
There is more than one code that will work with your unit, that will let you use are items, try different cage for that brand, and that will fix your problem.
Posted on Oct 16, 2010
Program RC27A Universal remote to converter box
Depends on the brand of converter box. Google rca rc27a remote programming. That should give you a programming link
Oct 17, 2016 | Universal Televison & Video
I need the codes for sanyo tv to program dta800b1 digital tv converter box remote model is rc27a
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
May 31, 2016 | RCA DTA800B1 Digital TV Converter
I need a 3 digit code for RCA converter box for a Orion tv.
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
Oct 04, 2011 | Orion STV2763 27" TV
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
I lost my remote for my rca converter box this remote works with my tv but wont on the converter box. Is there a code i need to make it work? or do i need another remote?
I can help you reprogram your RCA RCR311B for all your converter box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Dec 30, 2009 | RCA RCR311B Remote Control
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Converter box remote will not program
i have a admiral tv and i'm wanting to program my remote that goes to my converder box to the tv is there anyway i can do that?
Dec 27, 2008 | Insignia IS 20" TV040919 TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
