Bar on screen
Sears Super Scan Plasma TV Model # SSH2442, The tv has a permanent bar about 6" wide (from top to bottom )at center of screen.The picture is split but not distorted.What normally would cause this problem? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
All sustain parts in set need replacement.....costly!
Posted on Jun 03, 2008
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Plasma color TV screen developed dense black vertical line
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 21, 2009 | Hitachi SSH2442 Television
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
SuperScan Plasma TV SSH2442
here is one thing it could be cracked solder on the ribbon cables going to the screen there along the bottom of the TV if the bars line up with a connector it is probably your problem i will try to post the link to a hole writeup on it
Feb 07, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Wide white vertical bar down center of screen.
The only way to fix this is to replace the entire inside of the television, basicly the entire set except the case and power supply. I watched two repairman do this repair and this is not a do it yourself job. I asked them on a scale from a 1-10 how hard this job was for them, and almost before I could get the last words out of my mouth with this questions they both said a 10.
Oct 13, 2006 | Sony WEGA KE-42XS910 42 in. HDTV-Ready...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
