Question about Microwave Ovens
Hello Have owned this microwave a couple of years. Everything works on this microwave, ie clock, timer etc . It just will not heat anything, or defrost. I have unplugged it for 12 hours and plugged it into a different outlet, like the rep said to do, and held down the reset button for 5 seconds, but still nothing
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 16, 2010
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
WILL NOT HEAT BUT EVERYTHING ELSE WORKS, IE. TURNTABLE, CLOCK, ETC.
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.Yes they are right.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi there, everything seems to be working fine -- lights turn on, fan works, buttons all work, clock working, timer working, etc. -- but the microwave won't heat anything. any recs?
Generally, there are one of three failures.
Blown fuse in the Magnetron circuit.
The main capacitor failed (Required to power the magnetron)
The Magnetron itself has failed.
My local appliance repair guy helped figure out my last microwave failures. Once was the fuse the other was the capacitor.
The fuse was a couple bucks, the capacitor was $25 or so.
Generally, if you are not familiar with repairing a microwave, it is best to take it to a repair shop to be evaluated/repaired as it is real easy to get shocked working on one.
Dec 06, 2009 | Microwave Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
