Question about Rockford Fosgate Punch P6002 Car Audio Amplifier
Why does my sub static - Rockford Fosgate Punch P6002 Car Audio Amplifier
    Sergeant:
  • 293 Answers
Hi and thank you for using fixya:
I had the same problem in my car and it is a simple fix. You have to make sure that the subwoofer speaker and amp are no more thank 1 feet apart.
good luck
thanks
Posted on Oct 16, 2010
My amp is on but the subs don't work Kenwood amp
Ok. Simple test to check if your subs are blown. Hook up speaker wire and simply touch each wire to each end of a new aa battery. You should hear like a sizzling static sound from the sub and it should jump slightly if its good. If subs are good you may be having issues with the connection terminals or worse. And it could simply be the audio connection from the stereo or the audio wires need replaced. Possibly replace the stereo or amp. So many more options but this should get you headed in the right direction.
Sep 04, 2014 | Car Audio & Video
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
Mar 10, 2014 | Dell HK395 Computer Speakers
Subwoofer making static noise
first of all,do u have the strip wire in the red which is the hot side of the sub,next if that doesn't fix it u need to change ur spark plugs they will interfere when the engine is running,so call ur local auto parts dealer and ask for spark plugs that don't interfere with the radio.Hope this helps
Apr 03, 2013 | Power Acoustik Car Audio & Video
I get static thought my speakers they are hooked up though an amp im also running another amp thts running the sub i was seeing if u guys can help me fix the static noise
check all connections (speaker wires and rca jacks for shorts) replace them one at a time and listen if the static continues. Sometimes the static is due to a broken solder joint inside the amp either on the input or output connection post. hope this helps
Jul 20, 2011 | Car Audio & Video
Subs not working.
blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Sep 23, 2009 | Car Audio & Video
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
Help me with my problem.
Sounds like a conection problem. disconect all the cables clean the connectors with something like deoxit or any terminal cleaner. reconnect all cables making sure to make the correct conections. If you do not have a signal ground between your sub and amp you should consider it if it is a powered sub the signal ground can go to the preamp or whatever your driving it with.
good luck
Rob
Dec 03, 2008 | Kenwood kgc4042 Car Equalizer
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Not even static?!
if the flex wires are atached from the cone then the coil is disconnected.hit me up if you need more info.
Aug 09, 2007 | Dual XINBP-210 Car Subwoofer
Rockford Fosgate Punch P6002 Car Audio Amplifier Logo
69 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
