Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
My uniden dect 6.0 is not working at all on one phone and the other one is flashing like their is a message, and when I talk on it is beeps
SOURCE: voice mail notifier on a Uniden DECT 6.0
press and hold down [find hs] on the base for five seconds
Posted on Feb 20, 2008
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
SOURCE: I have a uniden dect
Hi, I have a dect 2035 and began having the same problem. I don't know how the feedback came about but it was suddenly there today when I tried using the phone. After mucking around with one of the handsets I hit the speakerphone button and turned the volume all the way down, it only goes down to a preset minimum, I then turned speakerphone off again and turned the volume for regular handset mode all the way down too. The phone works beautifully again!
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
When you select register on the base, you need to press and hold # on the phone... the instructions below worked for me, finally, to get the stupid waterproof handset registered. whew!
Registering the Handset
If you have purchased this accessory handset separately, it must
be registered to the base before you can use it.
Notes:
• The handset must be fully charged before attempting to register.
• Only one handset can be registered at a time.
1) If the other base has an LCD display:
• With the phone in standby, press [Menu/Select] on the base. Press [down] to move the cursor to REGISTER HANDSET and then press [Menu/Select]. HANDSET
REGISTERING appears.
If the other base does not have an LCD display:
• Disconnect the base AC adapter. Then press and hold
[find hs] or [find] while you reconnect the adapter. Keep
pressing [find hs] or [find] until the charge/in use LED
starts to blink.
2) On the handset, press and hold [#] until the handset beeps and displays HANDSET REGISTERING.
3) When the handset finishes registering, it shows REGISTRATION COMPLETE in the display.
Posted on Jul 20, 2009
THE BASE SET OF MY UNIDEN 1480-3 CORDLESS PHONE NO LONGER BEEPS WHEN I HAVE A NEW MESSAGE. CAN ANYONE HELP?
You can set or change the answering system options from any handset.
Open the menu and select Ans setup then select Message alert and activate it!
Beeps will be on!
Oct 05, 2014 | Uniden DECT 1480-3 Black Cordless Phone w/...
Out going message for uniden dect 6.o phone
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Dec 20, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
Cannot retrieve messages
shut it down and open it again.it will work
Dec 08, 2013 | Uniden DECT 6.0 Cordless Phone ID
My phone uniden DECT 6.0 cordless keeps flashing message alert when there is no message
You apparently have messages on your phone company's voicemail system. Please contact them for instructions on accessing their voicemail system.
Feb 21, 2012 | Uniden DECT 6.0 Cordless Phone ID
Personalize message and program phone set to ring/beep when a message has been received
Since you declined to say what model Uniden DECT 6.0 system, I can only direct you to select it from the list beginning here to download a copy of the manual.
Sep 16, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden dect 6.0 cordless phone with digital light keep flashing but can't retrive the message how do i clear the light flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Feb 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.o
What model Uniden DECT 6.0 phone/answering machine?
Mar 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
"i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Apr 13, 2009 | Uniden DECT 6.0 Cordless Phone ID
Voice mail notifier on a Uniden DECT 6.0
Feb 12, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
186 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
