Question about Toshiba TDP S3 Multimedia Projector
Optoma EP721 - reverse image
I have used my Optoma EP721 several time with no problems. Now, for some reason when it comes up the image is reversed on the screen.
As in - everything is backwards - right to left ? ?
  • Anonymous Dec 06, 2008
    EIK 4500 - image on screen is reversed
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Posted on Dec 12, 2008
    Problem Solver:
  • 8 Answers
He's right, it's set for a rear projection on a skrim as it sits
Posted on Jan 15, 2009
Service manual how do i take the cover off of my optoma EP721
Service Manual for Optoma series projectors.
http://easp.optomausa.com/ASP/upload/Optoma%20EP721_EP727_EP723_EP728_EW1610%20Family%20V6.0%20%28DDP2230-USB,%2036.88N03G001%29%20Service%20Manual.pdf
Aug 26, 2014 | Optoma EP721 Projector
My Optoma EP721 projects the desktop wallpaper but not anything else - no images of icons, can't see the DVD playing. Help please! Have to do a program tonight...
WELL IF YOU HAVE CONNECT IT TO A LAPTOP THEN PRESS FN AND F2.. (F2 OR SOME OTHER F KEY WITCH IT SWITCH THE SCREEN FROM LAPTOP TO PC AND OPPOSITE.. IF IT IS ON A DESKTOP COMPUTER THEN GO TO YOUR VIDEO CARD SETTINGS AND SEE IF IT IS TUNED AS AN EXTENDED DESKTOP.. IF YES THEN CHANGE IT :)
May 25, 2011 | Optoma EP721 Projector
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
Vertical balck bars all across the screen but still seeing the image
This is the sign of damage or dead transperant lcd optical image **** due to heat or vibration ,you have to replace that ****,
thank you
Feb 02, 2011 | Optoma EP721 Projector
Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
May 28, 2009 | Optoma EP721 Projector
Optoma ep721 remote problem
return the projector (still under warranty, if bought new). if it's used, reset the settings on the projector to factory default. if still nothing, replace the remore.
Sep 24, 2008 | Christie 38-VIV211-01 LCD Projector
Toshiba TDP S3 Multimedia Projector Logo
458 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
