Question about Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just got a new deep cycle battery {120 amp hour}.battery is running nothing but the electric.on the foot controls ,if i put it on the 1st and 2nd speed prop doesn't turn at all. thanks for your help.
    Problem Solver:
  • 7 Answers
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Posted on Oct 16, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    How to align the prop and nose (bottom) with the handle (top)
    FISH307 com Fishing Tackle Superstore
    This is a link that will allow you to look at a schematic for you motor.
    Minn Kota hand control motors have a small nut/bolt thru the motor shift aligning the handle with the lower unit. If yours does not line up your either missino this bolt or a previous owner altered the motor.
    Hope this helps.
    Oct 18, 2014 | Minn Kota Riptide St Saltwater 80 Bow...
    Minn kota
    I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
    May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Minn Kota rip tide st 55 very noisy
    is the prop shaft bent you may have busted a magnet in the motor dragging now
    Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
    Minn Kota riptide ST green ready light will not turn on. It started flickering and will not turn on now. Pressed the battery test button and it shows that the batteries are fully charged. HELP!!!
    Does the unit work without the auto pilot? Sounds like the auto pilot or the reciever is not functioning correctly.
    Check and make sure the unit is grounded properly, you may need to run a test ground wire from the battery to the motor istelf to check this.
    This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to check any circuit breakers
    Try cycling the auto pilot though the modes.
    there are 3 modes
    to cycle through each mode
    hold down the + and - key for 2 seconds
    this cycles you to the next mode. Last but not least, try turning the unit on and spinning the prop by hand to see if it takes off, the motor migt be bound up slightly or have a bad spot on the brushes.
    Dec 25, 2010 | Minn Kota Riptide St Saltwater 101 Bow...
    Riptide RT65 24 volt with auto pilot goes nuts.
    your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
    Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
    My minn kota riptide 55 stopped working when i turn the handle. i believe its a connection issue. i dismantled the housing around the handle and a little metal washer fell out broke in half and the pieces...
    Hi!
    To start with, here's a schematic:
    RT55 Hand Control
    Sounds like key# 87 broke....seen it before.
    To replace it, remove top cover, then remove the handle portion by removing the 5 screws underneath. There are a few peices in there, so keep close watch. Also be careful of the fine ribbon wire attaching the handle to the control board...it's pretty fragile.
    Best of luck!
    Mike
    Sep 27, 2009 | Minn Kota Riptide St Saltwater 55 Bow...
    Prop spins slow on any speed on the foot pedal
    There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
    May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Logo
    324 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
