Question about Bionaire BW2300 Window Mount Fan
Is there a way I can take the fan apart to clean it and put it away for the winter? I am afraid I'll ruin it if I get it wet.
I have asked this question 3 times! my whirlpool washer dryer, Model WET 3399XQO needs to be cleaned under the dryer vent. How do I get to it?
normally...one could take the whole dryer apart its..fairly easily put back together but at the same time you maybe able to clear all the lent out of the dryer even out of th heating element as well....done this before with a dryer that had an issue with the rollers being ruined...
Jan 06, 2017 | Whirlpool Dryers
Why could my gx160 be so hard to start in cold weather/
If you know how to take the carb off/disassemble it and check "o"rings for replacement you'll be good to go. You may have to buy a carb rebuild kit for your model. I have done several snow blowers this way and they start right up in the coldest weather -10. Use carb cleaner to clean it out and you may get lucky. Make sure to clean the emulsion tube under needle and seat. always run fuel empty for winter. use pumper and run a ll fuel out, if not use fuel stabilizer for summer or winter storage.
Feb 18, 2015 | 5.5 HP GX160 Engine
Had our window units stored for winter. went from apartment to home...how do I ensure they'll operate the way should? had one wrapped in plastic bags and placed in garage...water was comig out the bag
Make sure there are no mouse nests in the unit. The mildew can be killed with Lysol spray or the like. Pay particular attention to the filter if it was moist or wet. You can clean the condenser fins with a vacuum. You can a fan next to the unit to disperse any moisture. Move the fan around the unit.
May 23, 2014 | Haier HWR24VCB 23.6K RAC w/ remote Air...
I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
How to clean them
Clean your air tower fan by using small paint brush and wet rag(s). Turn off power and unplug, then open the fan by using screw driver either flat or crossed type. Eliminate dust and dirt using paint brush and rub it with wet rags. When disassembling put screws in box and be observant so that you'll able to assemble it later. Do not wipe motor with wet rags only the propeller, front back cover and so on.
Good luck.
Jul 17, 2011 | Lasko 48" Xtra Air Tower Fan with Air...
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
How do i take apart and clean my 2517 lasko t.f.
I took mine outside and hosed it down real good and then let it air dry for a day or 2. worked great! it was filthy!!! and that dang screw made it impossible for me to fully take it apart to clean it, so I decided it was either the hose or throw it away. mine was incredibly dusty and i was able to use a hose with a power nose and spray it really good. we'll see how long it works :)
Apr 30, 2011 | Lasko 2517 Tower Fan
Model 41.000-L range hood. Fan is getting electricity (very soft hum), but fan won't turn. Must it be replaced, or can it be cleaned, or ????
Sometimes they can be cleaned and oiled and they will work again...
Cleaning the grease and dust with out ruining the motor is the tricky part...
Take the unit apart as much as possible...spray down the fan part with a degreaser or strong cleaner...let it soak and they spray it down with water to rinse it off...
Then work a few drops of light motor oil into the motor by proping up the fan so that the oil will run down the shaft and into the motor...
then get it running smoothly by working it by hand...
Put it all back together and it should work again...
heatman101
Jan 13, 2011 | Broan-NuTone Kitchen Ranges
I can not figure out how to take the cover off of the fan so I can clean it.
I have the same 1 , I take mine outside and hose it out , dont spray the switch so much and let it dry very well before plugging back in.
Phil
Jan 12, 2009 | Honeywell HT-800 Table Fan
Bionaire BW2300 Window Mount Fan Logo
37 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Steve F
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
