Question about Whirlpool 24 in. DU1148XTP Built-in Dishwasher
My DU1145xTPQA whirlpool dishwasher is not cleaning like it used to it is leaving soap on the dishwear. It is about 5 years old and I wonder if some of the passages might be getting clogged by hard water deposits. I would like to run something through the washer to clear the deposits and/or remaove some of the rotating arms to check for restrictions.
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 16, 2010
Testimonial: "thank you floyd for your time and advice"
Leaves a white soapy film on pots, pans and dishes
Are you overloading your dishwasher? Are you loading the dishes in such a way to cover the water shooting up from the blades? Have you run your dishwasher a few times with no dishes in it, adding straight white vinegar to clean it out? How old is your dishwasher?
Apr 02, 2013 | Whirlpool Dishwashers
Have a whirlpool GU2400XTPT1 undercounter dishwasher for the past 5 years. Has worked perfectly until a few weeks ago the glasses and such on the top rack haven't been coming completely clean. Everything...
have you change you dish soap -to a phosphours free agent there has been rumor that these new cleaner will leave residue on glass.you can alos make sure the the dishwasher is clean after time they can build up lime and scale,calcium you can use any kind od dishwasher cleaner this may help
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool dishwasher that is not working properly. It is less han 3 years old. It is not cleaning the dishes properly and leaving a heavy film on the dishes which only came off by handwashing with...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
May 08, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Whirlpool dishwasher model # DU1145XTPQA I
You can try cutting the breaker off then back on.
Feb 22, 2010 | Dishwashers
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Our Kitchenaide dishwasher is approximately 4 years old, all my glass ware comes out cloudy and I have to wash it by hand.
Your using too much soap. Use 2-3 tespoons of name brand powder soap. Premeasured gel packs or tablets are too much soap as well. Cut them in half if u are using those. You can run a cycle with 5-6 cups of white vinegar with no soap or dishes to clean the soap residue from inside the dishwasher.
Apr 15, 2008 | Dishwashers
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1148XTP Built-in Dishwasher Logo
320 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
