Question about Honda 8 HP Engine
Honda GX 240 on woodsplitter stopped running. Tries to fire a couple of times each pull but dies. Found debris in gas tank. Cleaned out the tank and hose to carb. Cleaned out the sediment cup. Cleaned out the rust and debris from the bottom of the float bowl. sounds like debris in carb jets? Is it worthwhile taking the carb apart and cleaning it, or just order a new carb?
    Genius:
  • 1,126 Answers
Install a new plug, and make sure your gas mixture is not to rich, And you air cleaner is clean
Posted on Oct 16, 2010
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Have Honda HRB215 mower. Fired right up first use this season and operated fine. Week later fires first pull then dies after couple seconds. Drained gas and replaced, checked fuel filter, gas lines etc....
Have you checked the spark plug? Mine was doing the same thing. Not staying cranked and sputtering while running. I changed the plug and it runs like new. Hope this helps
Jul 11, 2012 | Garden
Honda GX 240 engine has spark, new carb; won't fire. what do I do?
remove the muffler and try it there is a screen inside the muffler that get carbon build up if it runs with out the muffler pry it open and clean it
May 24, 2012 | Garden
Stops running AFTER A COUPLE MINS
If it starts OK and runs fine for a few minutes you may have debris (dirt) in your gas tank. The dirt settles on the bottom, you start the motor and through vibration and shaking the dirt gets mixed up in the gas and sucked onto the fuel filter until the motor starves and dies. When the motor dies the dirt settles back on the bottom and you start all over. With the motor off, shake the gas up well and drain the tank into a bucket so you can check for debris. If there is a lot, half fill the tank, shake it up and drain again. Also, you may want to check your gas can to make sure the debirs isn't coming from there.
Sep 23, 2010 | Husqvarna Chain Saw 18" 450 Model...
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
2006 Arctic Cat ATV dies after about 15 minutes of riding
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
May 30, 2009 | Swisher Atv Tru Plow
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Honda 8 HP Engine Logo
131 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
