Question about Refrigerators
The refrigerator make a clonking noise intermittently, It seem to be at the end of a compressor cycle. I am not sure of the time between the cycles, but I started noticing the noise recently and it seems to be getting louder every time.
    President:
  • 1,891 Answers
This must be a older unit . and what you can hear is the compresor comming to rest . the clonking noise is the mounts inside the seald unit . have or are failiing . due to age . best solution is to run it till it won't . it may take years before it won't go . hope this hepled mm .
Posted on Oct 16, 2010
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Hi, my Miele G1142SC makes noise at startup
Mine is doing the same thing. I tried running a finish cleaner though a cycle. I did nothing I was about to do the same thing again when it just stopped doing it. What did you end up doing?
Jul 20, 2010 | Miele Dishwashers
Refrigerator shutting off intermittantly. I can
Something is causing the compressor to overload. That something may be parts on the main board or in start and run features of compressor. It also could be the thermostat just because of the way you explained. If you would like my assistance I will be here and back soon with more information related to the model PSW26P. I see that model for some reason has an electronic interface (digital touch pad). Are you sure about your model number? Please let me know the correct model number and I will be happy to assist you either way, Sea Breeze
May 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
LG Refridge LFX23961st
LG LFX23961ST Support Manuals Warranty More LG
I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements...
The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator .
Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and
you may hear a pulsating or high-pitched sound.
You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments.
As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator.
Contraction and expansion of the inside walls may cause a popping noise.
Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound.
You may hear air being forced over the condenser by the condenser fan.
You may hear water running into the drain pan during the defrost cycle.
I bolded the statement. Sounds like you are going to have to get used to the sound.
Semper Fi,
Z
Feb 01, 2018 | LG LFX23961ST Stainless Steel Bottom...
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
