Whenever i open word 2003 it gives a message ' word can not open the existing file" Normal.dot
  • 707 Answers
Was it made (the file) with word 2003? If not that might be your problem. You can always open it with Open Office Writer (free), it's compatible with everything.
available here:
http://www.openoffice.org/product/writer.html
Good luck
Posted on Oct 16, 2010
I don't understand why I have just started getting "Insufficient Memory" errors when I startup MP Navigator 3.0 I have tried downloading the latest driver for Vista but no change. Any...
There are a couple of things that can cause this. One is a corrupted normal.dot template, one is a corrupted printer driver, and the other would be some sort of third party add-ins. So let's start with the simplest to try and that is replacing the normal.dot template.
Click on Start, go to Search, and in the Search box type normal.dot. There should be a search option that you can check for 'search hidden files', make sure that is checked. If it does not find it, try searching for *.dot. It may be hard to find because it is a hidden file. You may have to go into folder options and be sure "show hidden files" is checked. Whenever you find normal.dot, rename it old.dot and restart your computer. Open Word and it will create a new normal.dot template, which is what Word uses as a default blank document.
If that does not work, read this article about a third party add-in that can cause this issue:
http://support.microsoft.com/kb/906899
Let us know how that works out and if you need additional help
Feb 20, 2011 | Computers & Internet
Word 2007 saves and closes normal.dotm everytime I close it. It doesn't ask for anything, but it shows as an opened document in Word and start menus list.
It could mean that the normal.dot file is corrupt.
Try this:
1. Do a search for normal.dot
2. when found, change the name to "normal.dot.old"
3. restart your machine
Good Luck !!!!!!
Jul 21, 2009 | Microsoft Office Professional 2007 Full...
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
Normail.dot is being used by another session when closing an Attachmate X-treme Session
This was fixed in an earlier release but the fix may have been dropped in V9. It happens even with SP2. The problem is that both Word and X-treme 9 have normal.dot template files. the solution is to rename the Attachmate Normal.DOT file.
May 27, 2009 | Attachmate EXTRA! X-treme
Transfering Macros, changing normal.dot files
Try to save the normal.dot file in my documents and then open with word, then close word and it should tell you that normal.dot has changed and ask if you would like to save it. Select yes.
Apr 29, 2009 | Compaq Presario 5000 PC Desktop
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
Adobe 8.0 Pro corrupts MS Office 2003 Normal.dot file
un-install and re-install office, or get the normal.dot file from other computer and copy it to yours.
Nov 06, 2008 | Microsoft Office Professional 2007 Full...
Office XP Pro
The "Normal" template opens whenever you start Word, and it includes the default settings for your new documents... as well as any customizations you may have opted for along the way. Sounds like your version of the normal template now includes the text of this document.
On the File menu, click Open, and then navigate to C:\Documents and Settings\user name\Application Data\Microsoft\Templates and look for "Normal.dot". You may need to change the Files of Type drop box to "Document Templates" to see it.
Open the file, select all the text you see there and delete it. Save the file and close it. You should get clean pages now when you open a new document.
Alternatively, you can use Windows Explorer to navigate to that same directory and delete the entire Normal.dot file. MS Office will simply create a fresh one when you launch Word again.
Hope that helps!
Good luck.
Sep 09, 2008 | Microsoft Office XP Professional OEM w/...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
