How do i shut down comand promptsw on my computer
  • 386 Answers
Hi Good day!!if you are using windows go to command prompt. press windows logo key + r to display run dialog. type cmd and click ok. in the command prompt type the following commands and press enter: shutdown.exe -s -f -t 0
-s = shutdown
-f = force shutdown closing all programs
-t = time in millisecond
0 = now you can change this no. to schedule your shutdown.
for ubuntu open terminal and type -sudo shutdown 0 you can change the 0 if you want.
Hope my solution help you!!
Posted on Oct 16, 2010
  • 707 Answers
Just like any other window. If it's taking up the entire screen use the taskbar to minimize it and/or close it. Or maybe try esc. Or if desparate use task manager Ctrl+Alt+Del.
Good luck
D2pad info
no comand system error? wont start
Apr 23, 2013 | Cell Phones
My comp dont run chkdsk after improper shut down lenovo m52
you can run chkdsk by your own by run the command on comand prompt
Dec 19, 2012 | Computers & Internet
Windows Viat will not shut down on comand, keeps rebooting
you might have a virus infection, I'll advise to use a free virus scanner like http://windows.microsoft.com/en-US/windows/products/security-essentials
after the virus scan, try turning off, if it repeats you can do a system restore using the microsoft system restore feature which can be found in the control panel
Mar 01, 2012 | HP Computers & Internet
I wanted to restore my Envy to a previous date. I got a message on screen ( initialising restore) and the computer is stuck like that for ten hours and it is not responding to any comand or even when I...
You will need to switch off the computer. The restore process might have been interrupted by certain factors yet to be known. So;
To switch off the computer, press the power button, holding it for about 10 seconds. (If it fails, remove the power cable and battery).
Switch on and start the process again. If the same happens, then your restore partition was tampered with. You might have to take to a technician for repair.
Dec 10, 2010 | HP Computers & Internet
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
Hi i have anti virus pro 2010 on my computer i have tried to remove through my task manager but it has shut down my administrator ihave tried to delete through comand prompt ihave tried file search to...
Go to your control panel and then go to programs. In your programs delete the programs that you want. Go through the control panel then programs to delete a program not task manager. Task manager only cancels the program use at that time it does not delete.
Oct 18, 2009 | Computers & Internet
PC can start again after turn off the swich only, without using window shut down. But PC cannot start again after window shut down. If this happen, need to remove the CMOS battery a while to start PC...
use comand f8 and del on your computer immediately when switching it on. this will lead you to a set up screen for bios options. enter the first option and change auto shutdown of your computer to manual. save the changes by f10 and continue to the booting sector to run windows. if it switches itself off though after changing values, then you should note that you windows might have been contaminated by a virus or nthe windows explorer registry is not working or interferes with other computer processes.
i advise you to run system recovery using either a disc that came out with you pc or use a windows cd to recover by running it as if you install a fresh copy and along the way it if it XP just after you agreed to the terms by microsoft it will say press R to recover. this will not let you loose your documents but it will replace the current operating system.
for vista, use the same windows cd you used when installing to upgrade, this will not also format your pc but replace the current windows.
rather, open you computer and on your motherboard, there it a watch like battery, remove it carefully and wipe it with a dry soft cloth. and put it back. some dust particles may conduct charges on it that makes the motherboard loose its memory and thus shut down the computer.
send me a comment if this did not work and some alternative ways would be suggested.
thank you
wonder
Sep 18, 2009 | Intel Motherboard
Eepc 900HA : Screen froze, then whent black. Activity and power lights still on. Removed battery/ reinserted and turned on. Got black screen with message " We apologize ... Four choices for restart...
good day.
with that problem may be your unit cannot shut down properly so as early as possible you must done with a proper shut downing of your unit.
so if that message will appear select on the "Last Known Good Configuration" and press enter, if this message will appear again you need to format your windows.
thanks...
Sep 10, 2009 | ASUS Eee PC 900 Notebook
Can't turn hibernation off...help
if you right click on the desktop and go to properties you will find the hibernation option in the power settings.
Jul 20, 2009 | Microsoft Computers & Internet
HP Pavilion Laptop dead?
Try unplugging laptop and take the battery out. Put battery back in and plug back in. If that doesn't work It would recommend taking it to a professional. The good news is that your data on your hard drive should be okay.
Thanks
Todd
Laptop Guy
Apr 23, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
