Sony trinitron kv 36xbr400 5 blinks 2 clicks then 5 LED Blinks then 1 click, Is it the tube?
  • Matthew Albert
    Matthew Albert Oct 22, 2010
    Checked cap's already,
    Is 5 blinks a PS problem?
  • Matthew Albert
    I cant seem to find any info about the 5 led flashing
  • 11,800 Answers
5 blinks signals that the jungle circuit no longer receives the return signal from the flyback transformer. No, this isn't the tube, but it's going to be very difficult to fix, parts for your tv are very difficult to find out. It's probably time to think about a new one.
Posted on Oct 22, 2010
    Genius:
  • 1,622 Answers
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help in solving the problem, take care.....
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Oct 22, 2010
    Hello, it's not a PS problem but a power problem which is from the power supply board.....
Sony trinitron kv 32fx68e has 14 blinks. So to switch it on you have to try 20 to 30 times. What can be the problem. Thanks
sony trinitron kv 32fx68e has 14 blinks light. that"s mention tv have bad picture tube. replace it . good luck!
Sep 22, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-27FS120 blinks 2 times continuously...
This is not for a DIY're.
It is possible that the flyback transformer and the horizontal output transistor have failed. Also there may be damage in the power supply when these components fail.
When troubleshooting, it is important that the tech locate the cause of the fault and also change the related components.
After the parts are changed, the power supply and the high voltage setups must be done to make sure that the voltages are in specs.
This type of work must be done by an experienced TV tech. He will have the necessary test equipment, tools, service manuals, and training. There are some very serious safety issues when working in a TV set.
Jerry G.
Jun 19, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY KV-27FS20 TV does not start
Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
May 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV 32FS120
Hiii...
I'm not certainly sure how many time the led blinking ?
I hope hear from tou soon...
Thank's
[Vrya]
be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 No picture, No sounds, 5 red blinks after turned on
your problem is in power supply section in your tv. if it is ok check for h/output section. call skilled tech to fix it it is not a major problem.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
