Question about Video Game Consoles & Games
Trying to hook up console for first time. Using my computer connection says IP address failed. Have dial up service only.
  • 43 Answers
If it's an xbox 360 you can't use dial up only broadband internet
Posted on Jun 03, 2008
My 360 pro wont connect online. it says "can't connect to your network hardware using static ip address" i do not know what a static ip is how do i check and fix that?
a static IP is when your computer's name (or IP address) doesn't change each time you log on. This is opposed to a dynamic IP that would provide a new IP address every time you go online. To fix this try these steps:
1. go to system settings on the xbox and select network settings. Restore factory defaults. 2. Restart your modem and router by unplugging the power source and waiting 30 seconds before plugging it back in
If all else fails, go to the xbox website and check under support or call 18004myxbox
Feb 11, 2011 | Microsoft Xbox 360 Console
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
Cant find ip address on ps3
If you are directly wired to your modem (not router), you will have to reboot your modem each time you switch between computer and console. When the modem boots up, it leases an IP address to the MAC Address of the connected device. Each device has a unique MAC Address. If the MAC Address does not match to the one it leased an IP to, it won't allow access to the internet.
You can get past this by "cloning" the MAC Address of your computer to your console.
To get the MAC Address (Physical Address) of your computer:
XP: Open the start menu, click "run" and type "cmd" then hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Vista: Open the start menu, in the search bar type in "cmd" and hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Now get into the network configurations on your console, look for an option of MAC Address cloning. Input the MAC Address of your computer, save and reboot.
Hope this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
This sucks
try to check the right ip address by connecting it first to your computer, check the ip address on your command prompt ( if you are using windows platform ) then type ipconfig /all
take note of your gateway, dns server, ip address ( so that your in the same network ) and the subnet mask.
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Ip address fails test connection
you need to set your 360's network to automatically detect your settings if you have other devices hooked up to the airport and they work it is not the Airport.
When it says IP address failed it has nothing to do with comcast it is your LAN having issues not your WAN
Mar 30, 2009 | Microsoft Xbox 360 Wireless Controller
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Mar 04, 2009 | Microsoft Xbox 360 Console
Xbox live ip address test fails
If you are using Windows XP or below, press START, click RUN and type "cmd". If you are using Windows Vista, press START, click the search bar and type "cmd". The command prompt should appear.
Type: ipconfig /all
Search the list for your network adaptor and make a note of the MAC address.
Turn on your Xbox 360 and go to network settings. Select manual settings and enter the MAC address under the Alternative MAC address option. Retest the connection. If your computer is connected to the internet, your Xbox 360 will be too,
Jan 24, 2009 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Internet Connection Difficulties
If you have a wireless modeum, then turn it off and then back on to give a fresh signal.
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
