Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I changed a gear kit in my craftsman opener once everything was installed I hooked up the wires again and when I try to run the motor it makes a clicking noise and does nothing else. The teach light is flashing 5 times. The motor worked fine before I took it apart.
    President:
  • 3,197 Answers
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Posted on Oct 16, 2010
Changed the gears out on opener and now it runs 3 inches either way. I did run it full up and down before hooking chain but now it wont do that.
Jul 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
I installed a sprocket and gear assembly kit to the garage door opener. It runs forward and then quickly runs backwards. Tried to adjust sensors and the motor does the same thing. Goes forward for a bit...
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door only moves 15 inches in each direction. I just installed a new gear kit.
Loosen the chain enough so that you can remove the chain from the sprocket above the motor. Run the motor until the sprocket turns in the clockwise direction and stops. With the door in the closed position replace and tighten the spring. This will get everything in sync and you will most likely need to tweak the 'up and down limit' controls to get it just right.
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
The motor runs but the chain is not turning. what
Take off the cover of the motor unit and you will find the drive gear is stripped. It is white nylon and is just in front of the motor. A new drive gear kit comes with installation instructions.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN 1/2 HP OPENER
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTMAN 1/2 HP OPENER
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? ...
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
How is the chain supposed to be aligned
sync the motor. the gear kit tells you how. get motor up and position trolley near motor, assuming you left chain/cable attached to trolley). Get motor up by running motor and then pushing button again. if motor reverse, let it run and it will stop in up position.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
53 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
