Question about Whirlpool GC5SHEXN Side by Side Refrigerator
Aligning front doors to same height
Cannot align doors with lower door height adjusment screw. using the adjustment screw still leaves the doors about 1/4 inch difference in height.
  • 1,314 Answers
Try adjusting the leveling legs also you can loosen the upper hinges and lift on the door with your toe the retighten
Posted on Jun 03, 2008
Why does door open when in use anew lock has been fitted but does'nt seem to hold the door in the closed position comes open by it self tumble dryer then stops any IDEAS ?
Take a close look at the installation of the latching mechanism. There may be a slight adjustment that could be made to cause the latch to fully engage. I'm thinking the replacement was not placed in perfect alignment and the latch is failing to secure the door.
Look to see if there are slotted holes at the mounting surface indicating adjustment potential. Look on both pieces of the door latch as the mis alignment could be on either. Also check the door spacing across the top. Is it perfectly aligned or is it lower on one side by a half-millimeter of so indicating a hinge issue? A subtle change in the height of the door on one side could be the cause of mis alignment of the latch.
Mar 06, 2015 | Dryers
How do I realign the fridge door with a top mount freezer
The top to bottom alignment is done by moving the hinges up/down. On many models there may also be plastic spacers on the hinge pins you can use to adjust the height.The closing of the door so it shuts properly and is flush on all 4 sides is done by adjusting the screws that hold the door gasket in place. If you've never done it before it can be a real pain to get it right. Make small adjustments to the screws and if need be grab the door at the center top and center bottom and give it a small tug in opposite directions to get it straight, if you have to. To test if its closing properly, look at the edge of the gasket all around it should be the same distance from the body of the fridge, use a mirror to see the bottom. To test if its sealing properly use a dollar bill. Close the bill in between the gasket and the door in areas all around the door, When you pull on the bill you should feel resistance, if the bill is not held in or pulls out easily the gasket is not sealing properly at that location, you need to adjust the screws to get it aligned better.
Feb 26, 2015 | Refrigerators
I need to adjust the sliding doors in my wardrobe so they stay on the do I do it
from the edges of the door you will find a hole that allows you to get to a normally a Phillips headed screw that is parallel to the track. This screw adjusts the height of the door on the roller body. It also adjust the vertical position of the door to make it line up with the opening edges . Turn both sides evenly to lift the door and then one side or the other to correct the opening alignment.
Aug 31, 2013 | Home
Bosch oven door is out of alignment
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Jan 12, 2013 | Bosch HBL 742 / HBL 746 Electric Single...
The door on my machine won't shut?
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
Adjustment of the fresh food door.
Normal for freezer door to be slightly higher, The upper hinges can be adjusted to make minor changes and raising the front roller under the rlower door will(or lower the higher side) help align them. It is a trial and error adjustment that takes time to get the best compromise of door alignment to cabinet setting.
Oct 16, 2009 | Refrigerators
Samsung RB215 -How do you remove the bracket that holds the door
The Cover hinge is misaligned, causing a no cool situation, the door switch and magnet are out of alignment, the door alarm is also on
The Blue arrow shows the hinge improperly aligned, the Yellow arrow shows the correct position of the hinge
f8ccb64.jpg Solution: Using pliers adjust the height of the hinge by pushing it down, the cover hinge will align properly as well as the door switch and the magnet, energizing cooling fan and
having refrigerator cooling properly.
Jul 27, 2009 | Refrigerators
How to install a rear window regulator on a 2000 Oldsmobile Intrigue
How do you remove door panels and replace window regulator on an Intrigue? Answer : For a 2002 Intrigue – Front Passenger I didn’t disconnect battery. You use window switch later to align window tabs to regulator frame – with ignition off power locks work, nothing is exposed.
1. Remove visible screw under armrest, pop out finger inset oval panel, remove exposed 2nd screw. 2. Pop off door handle trim – lock button assembly slide thru its hole in door panel. 3. Pop off window switch trim/holder – slide thru its hole in door panel. 4. Remove 2 slot screws under bottom of door.
5. I used a smooth metal letter opener (or old fork) to pry panel from door at each point plastic fasteners insert into metal. Start prying a little, see three on bottom perimeter two inches from edge. Three on door open edge and three on door hinge edge. Slow and easy = whole panel will pop off. A metal compression spring fastener connects at top door hinge edge trim – pry out. Be sure door lock and window switch remain inside. Clean all surfaces of door panel and lay on back seat.
6. With panel off you see clear plastic moisture sheet stuck to door with black rubbery paste - peel it from door for reattachment. You now see mechanism and fastener points. Lay out replacement window regulator and motor on mat by door to help you recognize fastening points, etc.
7. Carefully pull glass all way up and hold in place with two pieces duck tape two feet long with ¼# removal tabovers. Put a foot on outside glass and loop over door frame a foot to inside glass – with room to later redo when you twice lower and raise a foot to access bolts removing/attaching it to regulator bar.
8. Remove 3 bolts holding motor to door. 9. Remove upper 2 bolts and lower 2 bolts holding regulator frame to door.
10. Lower window to expose thru panel cutout area two bolts holding glass tabs to regulator, retape securely. Remove bolts, raise window, retape securely by looping over door frame.
11. Window regulator and motor assembly comes out as unit. Unplug window switch tab to release from motor. BEFORE reassembly clean the inside of the door, put in a little Borax for bugs, etc.
12. Reassemble by starting three motor bolts, fitting regulator assembly in door cavity. Replug window switch, motor can be placed in thru oval slots, leave all bolts loose. Replace two upper and two lower regulator bracket bolts, leave loose.
13. Turn on ignition, use window switch to lower window glass regulator tab bracket until accessible thru panel cutout. Turn off ignition, manually lower glass until tabs align with regulator bracket bolt holes and tighten these bolts. Take tape off, turn on ignition, raise window to top.
14. Tighten three motor bolts and four regulator bracket bolts, make sure alignment is OK. Remove your tape residue - clean goo from both glass sides with Goof Off. THEN raise and lower several times to assure all fits and works like new.
15. Reinstall clear plastic sheet, aligning any fastener holes and rubbing down perimeter with a cloth .
16. Align door panel, assure door lock and window switch are pulled thru. Visually align each tab on door opening side and pop them in one at a time. Continue on bottom – make sure you see them align or they will break. Finish on door hinge side and with metal fastener at top. IF you break a fastener, take one from small bag you bought from Pep boys - otherwise take bag back for refund…
17. Reinstall 2 armrest screws and 2 bottom panel screws, then pop in door lock, trim piece and window switch.
Clean the window inside and out with glass cleaner/polish/raineze so it will slide easily and your done. You can’t do anything about the motors going out. You can avoid regulator tab breaks by making sure the window is raised BEFORE closing those big doors – down is the weak moment!! I work slow and clean as I go, the job took two hours. I highly recommend – saved a bundle over dealer and they shipped everything in several days – as ordered!
Jul 27, 2009 | 2000 Oldsmobile Intrigue
Fridge door will not stay shut
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool GC5SHEXN Side by Side Refrigerator Logo
447 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
