Question about EliteGroup L4S5MG/651+ Motherboard
Load - EliteGroup L4S5MG/651+ Motherboard
    Genius:
  • 1,325 Answers
Pleas be more specific and precise with the issue -- what OS are you working with
what peripherals are used with this maonboard
go to this link to download drivers for the motherboard
http://www.nodevice.com/driver/L4S5MG_651___V5_0A_/get63918.html
Posted on Oct 16, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Tip
Load Resistor Testing for 4400CL and 4600CL Steppers
This video covers troubleshooting of the load resistor on the Stairmaster 4400CL and 4600CL Steppers.Tools Needed: Multi Meter
The load resistor is cylindrical in shape and has metal fins encased in the ceramic coating around the outside. The job of the load resistor is to take the extra electricity from the alternator and dissipate it as heat. Symptoms that one may experience when the load resistor fails are alternating resistance in the pedals or no resistance in the pedals. Alternating resistance can occur as the load resistor heats or cools causing the resistance to come and go. If the load resistor is really bad, there can be no resistance in the pedals.
You can test the load resistor by first following the wires from the load resistor to the lower control board.
Next, carefully disconnect the load resistor wires from the lower control board. Be careful not to damage the connector on the lower control board or the load resistor wires.
Set your volt meter to the setting larger than and closest to 2.5 ohms. Insert each lead from your volt meter into the pins of in the wire connector of the load resistor.
Look for a reading of 2.5 ohms (+/- 10%). If your reading is outside the range, the load resistor should be replaced.
Load Resistor Testing for Stairmaster Steppers 4400CL 4600CL
on Feb 11, 2015 | Stairmaster 4600 Cl Cordless Freeclimber
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My front load washer had ue blinking after a load was supposed to be finished. The clothes were soaking wet like the washer didn't spin
UE is imbalance error...Usually because a load in the machine is unable to distribute itself around the inner drum, and the machine senses the load as imbalanced.....Good Luck Nomess
May 21, 2010 | LG WM-2277HW Front Load Washer
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Are load range D Uniroyal Laredo LT225/75R16 load range D tires satisfactory, if hauling a full load of passengers or should D Uniroyal Laredo LT225/75R16 load range E be used. 2500 model
The load range refers to what used to be ply ratings, it is now the grade for holding pressure at load, a "D" range is equal to 8 ply, and the load index for this tire is approx 2300lbs/tire, the "E" rating is equal to 10 ply, and the load index is approx 2700lbs/tire. If you are hauling 12 passengers at 200lbs/passenger plus driver total is 2600lbs. I would say the "E" rated tire is better for that application. If you need more info you can go to google and type in understanding tire markings or ratings, and there are several sites that will cover all tire markings in depth, I hope this helps, let me know
Jun 03, 2009 | 2004 Chevrolet Express
EliteGroup L4S5MG/651+ Motherboard Logo
32 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
