Question about Acer 4220-2346 Notebook
The problem is in its power.. it won't turn on when i press the power button, despite of full batt and on ac adaptor...i have to wait and try many times before it opens..
    President:
  • 2,653 Answers
It's possible that the button board is bad, I'd recommend removing it and pressing the button direct to see if that's the cause. Based on what I saw online, I'd say you could probably just apply some light force with a FLAT screwdriver and remove it.
There could be two screws holding it down, but from I see in THESE picture it looks like it just snaps onto the laptop.
Posted on Oct 16, 2010
Won"t power up. If I hold the power button down an icon on the lower right flashes on but nothing else happens.
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer. If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Sep 29, 2014 | Dell Precision Computers & Internet
Unit does not boot. When power button pressed, activity light comes on about 1 second and extinguishes again. Have removed batt for several minutes and tried AC Adaptor.
Have the Mainboard Replaced, if this does not fix then also replace battery and AC Adapter, thats what i had to do with my Acer.
Apr 13, 2010 | Acer Computers & Internet
I got the code C:31:22 flashing on the screen. what should i do?
this error pertains to one of the reels (the thing that turns the tape)is malfunctioning.so most likely you'll be having issues w/recording,playing,fast forwarding or rewinding the tape.you can try RESET (press the reset button located inside and beside the eject button in the tape compartment cover, while cam is on).if it doesn't work try POWER RESET (turn cam off,remove the batt,make sure the ac adaptor is not connected.turn power switch to camera or player, and leave w/o power for at least a minute.turn power switch back to off and reinsert batt.check if working).if still you get the error,repair might be needed.hope this helps.thanks:)
Apr 06, 2010 | Sony Handycam CCD-TRV608 Camcorder
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
DELL Precision M65- cannot turn on. Even take off batt then turn ON, or using adaptor without battery still cannot turn ON. The LED light is ON but no visual/screen. Please help. Many thanks...
Verify the AC power adapter displays a solid green or blue light. Older Latitude™ C Series laptop computer AC adapters may not have a light.
Run the diagnostics on the system as follows , connect both the battery and the Ac adapter before running the diagnostics
  1. Ensure the system is powered off.
  2. Remove all external peripherals.
  3. Press and hold the <Fn> key on the keyboard.
  4. Continue to hold the <Fn> key while pressing the power button.
  5. Release both buttons.
  6. Note which lock LEDs are lit (lock LEDS are next to the power button)
And proceed with the troubleshooting steps listed below
http://tinyurl.com/m3k22x
Thanks for using Fixya
Proton
Jul 13, 2009 | HP Pavilion dv6000z Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Acer 4220-2346 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
