Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 Flat Screen TV capacitor 2200/16 needs replacing. But I can only find 2200/10. Think this is good enough or should I go higher in voltage like 25 or higher?
  • Vincent Oct 18, 2010
    Happily enough I did find the capacitor that I needed but rated 85 C rather than 105 C as the original stated. Gave it a shot and TV is up and running now. Kind of concerned about the lower rated degrees in the new 2200/25 one though?
    Genius:
  • 1,030 Answers
The common practice is never go down in voltage rating. as a technician i would defintly not go down to 10 volt i suggest you go up 25 would be ok if you can get it to fit
Posted on Oct 16, 2010
  • Vincent Oct 16, 2010
    Thank you. I needed that confirmation. Now the dreadful task of finding the needed capacitor.
RCA D52W19 suddenly stopped turning on.Light comes on then shuts off right away.Tried unplugging to reset,but no difference.
Posted on Apr 16, 2011
Model l42wd22yx5 ser. h204cuoaf wont come on red led on front blinks 5 times cant find error code to see whats wrong
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Apr 03, 2011 | RCA Televison & Video
Rca tv modle #27v414tyx8. wont turn on. the red light next to the power botton comes on but no pic
I hope this helps.
Good luck.
Mar 12, 2011 | RCA Televison & Video
Tv does not come on
I hope this helps.
Good luck..
Mar 11, 2011 | RCA Televison & Video
It tries to power on but wont
I hope this helps.
Good luck.
Feb 22, 2011 | RCA D52W19 52" Rear Projection Television
I have an RCA P52937 Projection screen television which needs the high voltage splitter replaced; what part number is compatable with my tv wich was made in june/july 2001?
high voltage splitter original part number - 205064 i suggest getting the asti alternative which is part number AI-2841 they are about $30.00 good luck
Jan 07, 2011 | RCA D52W19 52" Rear Projection Television
Rca tv d52w19 shuts-off
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.
use the same type of value to replace.
Good luck...
May 25, 2010 | RCA D52W19 52" Rear Projection Television
Hi there, I have a RCA DRC8052N and I did get the stuck on ''Hello'' message and was able to reset by pressing the power button for 10 Secs. I was just wondering which Capacitors are responsible for this?...
Found the ground wire solder point on the main board and it needed to be re soldered. Tested for continuity and put it back together and it worked.
No more intermittent cut offs.
Dec 29, 2009 | RCA RS2663 Shelf System
I have the same problem with the RCA d52w19. The green led flashes and the tv doesn't turn on. How do i know if the capacitors are bad?
the tops of the CP150, CP114 and CP120 should be flat . If they are even slightly domed, they will need replacement.
Dec 13, 2009 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Jun 02, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
566 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
