Question about Kenmore Dishwashers
I have a Kenmore Quitemode 4 dishwasher and the detergentdispenser won't empty. The door opens but it is full of caked on dishwasher detergent. I cleaned it out and ran it again, same problem. I am using the same detergent. It is as though the water isn't getting to the detergent but there is definitely water. Any ideas? Thanks
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 16, 2010
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
The dishwasher detergent dispensor door opens, but it does not eject the detergent into the tub. The detergent cakes, and the dishes remain dirty. Additionally, the dishwasher has become much louder than...
heatman101
Sep 21, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Soap dispenser door doesnt open during wash cycle
I have had this problem on a dishwasher IF I overfilled with powdered detergent. It would cake and the door would not open. Now I always leave a little space.
Mar 27, 2010 | Roper 24 in. RUD4000M Built-in Dishwasher
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
Detergent Fill Dispenser
It may be gummed up inside with old detergent that has caked on . Try rinsing out the despencer until it opens and closes easy. DFD
Apr 22, 2009 | Dishwashers
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
My 3 year old
Try a different detergent such as the electrosol tablets. Also might add vinegar to an empty cycle to clean dishwasher, or with dishes.
Oct 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Soap dispenser will not open in cycle
Hi Dookie1984
I'm Harvey the Master Plumber.
Your question is about: The small door that houses the dishwashing detergent (grain or gel) will not open during the dishwashing cycle. The detergent gets caked in that housing. This has happened about 10 times now in a row.
If it is still under warrenty it's time to make the call. If not then it may be time to consider whether it's more cost effective to repair or replace. Unfortunatly you won't be able to fix this and sometimes even the repairman can't. You can always utilize our Repair Directory if you decide to go in that direction.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Kenmore 15129 Built-in Dishwasher
DISHWASHER. M0DEL # C97873320-2, HYDRO MASTER
run the machine with the cavity closed, but no detergent. see if it is open at the end. if it is, then its probably being overfilled or has enough residual build up on the pivot mechanism that it wont open. also, wash water may be getting to the detergent before it opens and then it cakes up and swells against the cavity door and impedes the normal opening event. you can check for clearance when the cav door is closed.
it is not likely the timer. running it empty will be a good way to know. it is released by an electrical mechanism. if the wires are damaged where they feed through the bottom of the unit into the door, it would be a reason it does not work. otherwise, the mechanism or electromechanical mechanism could be replaced as it is likely many times less expensive than timers. usually.
mark
Dec 18, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
