Question about Kenmore Washing Machines
Kenmore elite washerabout 5yrs old model 170 ser# CK4512109. washer panel reading "Ld" washer came with house no manual
  • 487 Answers
Means long drain.
Either pump is plugged, drain is clogged or filter is clogged.
Please check filter, drain and than pump.
Posted on Jun 03, 2008
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Ld Long Drain Ld flashes
ld indicates a LONG DRAIN. yo ucan remove the lower panel and clean the filter housing, this will impede the draining abiltiy
Feb 09, 2010 | Kenmore Elite 45986 Front Load Washer
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Ld code, will not drain, will not turn off
there is something stuck in your pump remove the back panel and you should check the drain pump the pump that is on the bottom left. good luck
Jan 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer problem
Click on kenmore (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
Feb 09, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
