Question about Mitsubishi WS-55513 55" Rear Projection HDTV
All of a sudden the convergence is out of allignment and I am not able to correct it following the owner's guide instructions
    Genius:
  • 1,030 Answers
Looseing convergence all of sudden is definatly of component failure... with convergence there a good chance the chips that control convergence have failed. ... these chips called stks. do you have any convergence at all. when you tried to align did the crosshairs move at all left right blue red? if you have any control it might be what is called a resistor ...let me know and i will try to help
you might need a technician to help this is a involved repair
Posted on Oct 16, 2010
There is a green line that surrounds things, like a 3d image. the green is out of allignment. Can i order the parts i need?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 22, 2011 | Hitachi 53FDX20B 53" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
Colors on tv look like 3d, ihave tried to adjust the crosses so they will allign but some do not go all the way to where they are completely lined up.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Sony Televison & Video
Our panasonic HDTV-model #PT47WX42F all of a sudden has 3D images- I've tried to correct with the convergence buttons but can't get the colors aligned--can you suggest something to try or is it...
You can repair that issue by installing a convergence repair kit. You can get the repair kit for your model which has the parts and detailed instructions at the following link listed under the Panasonoc repair kits. www.tvrepairworld.com
Aug 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
My color is not alligned.
you can get the DPTV305 -345 convergence repair kit at the following link which should fix that. The kit contains the parts and detailed instructions on cd
http://www.tvrepairkits.net/
Jul 11, 2009 | Philips 55PW9363 55" Rear Projection...
Convergance
Change both convergence Ics. You can get new replacements at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Red and white allignment
you need new convergence Ics. This is a easy repair. let me know your model number of your TV and I will post the Convergence ICs numbers and also post a link where you can get new Ics that come with free installation instructions with pictures and free on line tech support.
Apr 23, 2008 | Televison & Video
Convergence
mammy: In the MENU when your correcting this problem in order to use your remote you must press the M button or MENU button. Once it is done then you can adjust the color convergence. I also suggest you to check the remaining 2 colors for a nicer setting. SithPitt
Jul 04, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
