Question about Sharp AL-1641CS Laser Digital Copier
Sharp 1642, erro L1 - Sharp AL-1641CS Laser Digital Copier
  • 1,110 Answers
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Oct 17, 2010
  • nrabek Jun 11, 2011
    Great advice. Thanks! Apparently I nudged the scanner lock while moving the machine and didn't even realize that the lock existed. A quarter turn later, and all is well.
  • njpirro
    njpirro Feb 13, 2012
    my dad though it was garbage and not to invest any money into the machine, if it didnt work. i read this post and greased up the rail and its been running perfect ever since, thanks dad... thanks fixya!
Tip
All sharp 1631 and 1642 models have scan unit problem.
When scan unit doesn`t move you have (L1-from left to right)and (L3-from right to left)code or blank copy (white).first must check scan uniy lock under the scan unit-then service 2 plates that scan moves on it.
on Jun 01, 2010 | Sharp AL 1631 Copier
ESTÁ DANDO MENSAGEM DE ERRO L1 NA COPIADORA AL-1631
L1 signal means your copier exproser lamp carraige is not home position.Clean all surface and sensor hten solve it
with the best luck
Aug 03, 2010 | Sharp AL 1631 Copier
Sharp ar-m205
L1 indicates the laser mirror motor is bad. The laser would have to be replaced to fix properly.
Jul 29, 2010 | Sharp AR-M205 Copier
Al 1642 cs drum light
You need to press These keys; C- Auto- C -Auto , Display off.
24 Print, 7 Print , 00 will display then press C twice.
Jun 30, 2009 | Sharp AL-1642CS Copier
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
Sharp 1642 E7 10
Yes it can the error code means that the ccd black level problem
May 07, 2008 | Office Equipment & Supplies
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Sharp AL-1641CS Laser Digital Copier Logo
441 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
