Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Unusual fan noise
My refrigerator seems to be making more noise than usual. It sort of sounds like a fan that is starting to struggle to spin. The sounds seems to be coming form the upper part of the freezer side. in my bottom freezer Amana refrigerator (about 3yrs old) a sudden loud noise started this am. It lasts about 20 mins on and about the same amt. of time off. It is louder from the inside when door/s are open.
  • CARE4U Jan 02, 2009
    Amana SC22HW - My refrigerator seems to be making more noise than usual. It sort of sounds like a fan that is starting to struggle to spin. The sounds seems to be coming form the upper part of the freezer side.
    President:
  • 1,314 Answers
Sounds like you need a new fan motor or blade
Posted on Jun 03, 2008
Im having a problem with some sort of power issue, sometimes it works and sometimes it just doesnt come on. i can hear a buzzing noise but it doesnt spin can you help thanks
Hi!
I think I had this kind of issue before on my computer. I sorted it out. First I check the motherboard and wiring inside if there are any wires touching the fans because of the buzzing sound. Found nothing. I noticed that the buzzing sound came from my hard drive. It seems that it's not getting enough power that's why its struggling to spin. What I did was I changed my power supply to higher wattage and everything was fine after that. You can give it a try though. If it still the same issue, you might as well try a different hard drive.
Regards!
Feb 14, 2011 | Computers & Internet
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Unusual Noise
The compressor and condenser fan are at the back. The fan could be hitting somthing. The internal parts of the compressor could make a noise usually when it cut on or off.
Sep 02, 2009 | Refrigerators
My GE side by side seems to be struggling. the
If you were low on refrigerant you would not have a good temp. Sounds like the evaporator and or condenser fan is going bad.
Aug 21, 2009 | Refrigerators
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Unusual fan noise
YOUR FREESER FAN IS GOING BAD ,REMOVE FREEZER PANEL TO EXPOSE FAN,HOLD FINGER ON FAN,RELEASE IF FAN DOES NOT START REPLACE,THANKS-MIKE
May 29, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
491 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
